    Need help setting up L3 switch w/Multi vlans behind pfsense
    4 Posts 4 Posters 491 Views
      skeltic
      I would like the l3 switch handling all of the inter-vlan routing, but cannot seem to figure out how to set static routes properly on pfsense
      On switch
      vlan 1 - 10.1.10.0/24
      gateway - 10.1.10.1
      pfsense 10.1.10.254
      ip route 0.0.0.0/0.0.0.0 10.1.10.254
      Currently can reach the internet
      vlan 100
      10.1.10.0/23
      can ping other vlans but cannot ping 10.1.10.254
      vlan 192
      192.168.100.0/24
      pfsense
      added 10.1.10.1 as a gateway on lan
      added 10.1.100.0/23 with 10.1.10.1 as gateway - on lan interface
      currently only have an all access default rule in firewall
      any help would be appreciated getting vlan 100 and 192 to reach outside across the vlan 1 gateway
      • V Offline
        viragomann
        I don't understand your setup.
        @skeltic:
        On switch
        gateway - 10.1.10.1
        pfsense 10.1.10.254
        What is the gateway - 10.1.10.1? An upstream gateway?
        However, the default route is set to 10.1.10.254, the pfSense vlan1 IP.
        Is pfSense the upstream gateway or another device, now? If it is pfSense, it has to have an IP in each vlan and do not need static routes at all.
        • V Offline
          Varaphansin12
          I need the same switch.
            I think he means the switches SVI is 10.1.10.1??
            If your switch is L3 and doing the routing between your downstream vlsns, then it would need an interface with IP in each of these vlans.  This SVI becomes the gateway devices in these vlans.
            The network between pfsense and this downstream router now is just transit.
            A /24 is a huge transit - you do not have hosts on these network do you.  If so you going to have asymmetrical routing unless you create routes on each host.
            For pfsense to be an upstream router the interface that is the transit needs to allow for the downstream networks.  And if you changed the outbound nat rules from auto you will have to adjust those after you create your gateway and route(s) on pfsense telling it which networks are downstream.
            SG-4860 26.03 | Lab VMs 2.8.1, 26.03
