    1 WAN to 2 LAN - Port Routing Problem
    4 Posts 3 Posters 742 Views
      bymiy
      Hello friends,
      First of all, I mean the production. I will tell you the problem that I experienced afterwards.
      Thank you for your interest.
      I created a system with 3 ethernet cards. On Pfsense 2.4.2 installed. Ethernet legs and ropes as follows.
      WAN - PPPOE (78.189.X.X)> HTTPS - 19753 & SSH 19574 (External access is available.)
      LAN - 192.168.2.254> DHCP (192.168.2.10-192.168.2.200) - PCs are coming out by this network.
      CAM - 192.168.3.254> DHCP (192.168.3.10-192.168.3.100) - Camera (NVR) is coming out by this network.
      In this case, when I create NAT by WAN (WAN> WAN address> 19753 Port> 192.168.2.254 & WAN> WAN address> 19574 Port> 192.168.2.254) I can access the pfsense device from outside with both https as webgui and I can do SSH with Putty.
      The problem I'm having here is port routing on the CAM side. When I make NAT to the CAM leg, I can not reach the ports on the CAM side and the jeeps outside. I write the following:
      WAN> WAN address> 23560 TCP Port> 192.168.3.40
      WAN> WAN address> 23561 TCP Port> 192.168.3.40
      WAN> WAN address> 23562 UDP Port> 192.168.3.40
      In other words, I can access LAN LAN from outside by WAN. But I can not access the CAM leg by the WAN. But there is an exit from CAM by the interne. Any PC can be output directly internete.
      I would like your assistance in this regard. I could not find any information on my research. 2 WAN to 1 LAN operations are available everywhere.
      interface-ip.jpg_thumb
      • V Offline
        viragomann
        Are you able to access the cam by its internal IP from a PC in the LAN network?
        • DerelictD Offline
          Derelict LAYER 8 Netgate
          Probably the default gateway in the camera.
          https://doc.pfsense.org/index.php/Port_Forward_Troubleshooting
          Chattanooga, Tennessee, USA
            bymiy
            Hello friends,
            We solved the problem. Thank you very much for your help with Derelict  :).
            The gateways of NVRs are located at 192.168.3.1. I have updated 192.168.3.254.
            Goodbye.
