    [SOLVED] Problem Vlan Trunk with cisco switch
    46 Posts 5 Posters 8.1k Views
    • O Offline
      omarmohammed
      it doesnt say here vlan & priority on my nic, but on the vmnet7 (used) and generated with pfsense there is the priority and vlan enabled, like in all other vmnets !!!
      ![Sans titre.png](/public/imported_attachments/1/Sans titre.png)
      ![Sans titre.png_thumb](/public/imported_attachments/1/Sans titre.png_thumb)
        gjaltemba
        It looks like the AR8151 driver can be assigned to a single VLAN ID. What do you have in the property for VLAN ID? Try entering 20.
        In my driver, there is a VLAN tab to add vlans. In this approach, the parent interface and child vlans are handled by the driver.
        • O Offline
          omarmohammed
          changing it in the nic doesnt do anything ! same result as before exactly (change it => delete the link between pfsense and switch => wait a liittle => put it again, still vlan 1 + mac int of pfsense in the mac add table, and the two others from the end devices (with vlan 10 and 20). With the router in the place of psense i get the 5 correct entries) ><
          also : i get two entries sometimes in the mac add table of the switch coming from the int f0/0 (pfsense) with vlan1(everything coming from pfsense is only vlan 1 always it's like there is no vlan set) and int f0/1 (PC) (with vlan10)
          those entries come and go, and are not related to pfsense interfaces and i noticed its coming only from VMs. i guess its harmless anyway it doesnt do nothing
          • O Offline
            omarmohammed
            if u can tell me if i have anything wrong …
            I'm trying to bridge the pfsense interface with a microsoft loopback interface
            and connect the switch to the cloud's microsoft loopback interface but it's not working
            https://gns3.com/discussions/trunking-dot1q-between-vmware-vm
            • O Offline
              omarmohammed
              OW MY GAD FINALLYYYYYYYYYY WORKING
              as i thought it was a vmware problem ! the "host only" interface doesnt interpret the dot1q !
              so i did this : https://virtuallyfun.com/wordpress/2016/01/19/getting-dot1q-to-work-between-vmware-and-gns3/
              IT'S WORKING now yees thanks everyone for the support and specially gjaltemba who was close
                gjaltemba
                Glad to hear that you have the trunk port working. Thanks for posting the final solution.
