    Problem: PfSense does´n allow traffic on wan nor distribute DHCP on lan
    1 Posts 1 Posters 2.0k Views
      CalleJ
      I have quite the issue… Set up a PfSense-box yesterday using my old computer, installed it and configured it to use a static IP-adress from my ISP and to distribute DHCP on the LAN-interface. The problem is that it won´t connect to the WAN, but It says that the interface is up, and client (lan)-side it simply won´t distribute DHCP to the clients.
      Checked the WAN-side on both my laptop and another router with the same settings, which works perfectly.
      I've been looking through the logs, yet I can't really see what the problem is!?  ???
      Jan 30 02:53:58
      sshlockout[739]: sshlockout starting up
      Jan 30 02:53:58
      Jan 30 02:53:58
      login: login on ttyv0 as root
      Jan 30 02:53:56
      check_reload_status: check_reload_status is starting
      Jan 30 02:53:56
      php: : Resyncing configuration for all packages.
      Jan 30 02:53:55
      dhcpd: For info, please visit http://www.isc.org/sw/dhcp/
      Jan 30 02:53:55
      dhcpd: All rights reserved.
      Jan 30 02:53:55
      dhcpd: Copyright 2004-2006 Internet Systems Consortium.
      Jan 30 02:53:55
      dhcpd: Internet Systems Consortium DHCP Server V3.0.5
      Jan 30 02:53:54
      php: : Creating rrd update script
      Jan 30 02:53:54
      php: : No default gateway detected, adding 192.167.44.65
      Jan 30 02:53:51
      mpd: [pt15] using interface ng16
      Jan 30 02:53:51
      mpd: [pt15] ppp node is "mpd454-pt15"
      Jan 30 02:53:51
      mpd: [pt14] using interface ng15
      Jan 30 02:53:51
      mpd: [pt14] ppp node is "mpd454-pt14"
      Jan 30 02:53:51
      mpd: [pt13] using interface ng14
      Jan 30 02:53:51
      mpd: [pt13] ppp node is "mpd454-pt13"
      Jan 30 02:53:51
      mpd: [pt12] using interface ng13
      Jan 30 02:53:51
      mpd: [pt12] ppp node is "mpd454-pt12"
      Jan 30 02:53:51
      mpd: [pt11] using interface ng12
      Jan 30 02:53:51
      mpd: [pt11] ppp node is "mpd454-pt11"
      Jan 30 02:53:51
      mpd: [pt10] using interface ng11
      Jan 30 02:53:51
      mpd: [pt10] ppp node is "mpd454-pt10"
      Jan 30 02:53:51
      mpd: [pt9] using interface ng10
      Jan 30 02:53:51
      mpd: [pt9] ppp node is "mpd454-pt9"
      Jan 30 02:53:51
      mpd: [pt8] using interface ng9
      Jan 30 02:53:51
      mpd: [pt8] ppp node is "mpd454-pt8"
      Jan 30 02:53:51
      mpd: [pt7] using interface ng8
      Jan 30 02:53:51
      mpd: [pt7] ppp node is "mpd454-pt7"
      Jan 30 02:53:51
      mpd: [pt6] using interface ng7
      Jan 30 02:53:51
      mpd: [pt6] ppp node is "mpd454-pt6"
      Jan 30 02:53:51
      mpd: [pt5] using interface ng6
      Jan 30 02:53:51
      mpd: [pt5] ppp node is "mpd454-pt5"
      Jan 30 02:53:51
      mpd: [pt4] using interface ng5
      Jan 30 02:53:51
      mpd: [pt4] ppp node is "mpd454-pt4"
      Jan 30 02:53:51
      mpd: [pt3] using interface ng4
      Jan 30 02:53:51
      mpd: [pt3] ppp node is "mpd454-pt3"
      Jan 30 02:53:51
      mpd: [pt2] using interface ng3
      Jan 30 02:53:51
      mpd: [pt2] ppp node is "mpd454-pt2"
      Jan 30 02:53:51
      mpd: [pt1] using interface ng2
      Jan 30 02:53:51
      mpd: [pt1] ppp node is "mpd454-pt1"
      Jan 30 02:53:51
      mpd: [pt0] using interface ng1
      Jan 30 02:53:51
      mpd: mpd: local IP address for PPTP is 0.0.0.0
      Jan 30 02:53:51
      mpd: [pt0] ppp node is "mpd454-pt0"
      Jan 30 02:53:51
      mpd: mpd: pid 454, version 3.18 (root@freebsd7-releng_1_2.pfsense.org 20:18 9-Nov-2008)
      Jan 30 02:53:51
      dnsmasq[449]: read /etc/hosts - 2 addresses
      Jan 30 02:53:51
      dnsmasq[449]: using nameserver 195.129.12.76#53
      Jan 30 02:53:51
      dnsmasq[449]: using nameserver 192.129.12.83#53
      Jan 30 02:53:51
      dnsmasq[449]: reading /etc/resolv.conf
      Jan 30 02:53:51
      dnsmasq[449]: compile time options: IPv6 GNU-getopt BSD-bridge ISC-leasefile no-DBus no-I18N TFTP
      Jan 30 02:53:51
      dnsmasq[449]: started, version 2.45 cachesize 150
      Jan 30 02:53:50
      Jan 30 02:53:50
      Jan 30 02:53:50
      Jan 30 02:53:50
      Jan 30 02:53:49
      Jan 30 02:53:48
      kernel: sk0: link state changed to UP
      Jan 30 02:53:46
      Jan 30 02:53:46
      pftpx[345]: listening on 127.0.0.1 port 8021
      Jan 30 02:53:46
      Jan 30 02:53:45
      kernel: pflog0: promiscuous mode enabled
      Jan 30 02:53:45
      kernel: sk0: link state changed to DOWN
      Jan 30 02:53:45
      Jan 30 02:53:45
      kernel: nfe0: link state changed to UP
      Jan 30 02:53:44
      kernel: GEOM_LABEL: Label ufs/pfSense removed.
      Jan 30 02:53:44
      kernel: GEOM_LABEL: Label ufs/pfSenseCfg removed.
      Jan 30 02:53:44
      kernel: GEOM_LABEL: Label for provider ad0d is ufs/pfSenseCfg.
      Jan 30 02:53:44
      kernel: GEOM_LABEL: Label for provider ad0a is ufs/pfSense.
      Jan 30 02:53:44
      Jan 30 02:53:44
      Jan 30 02:53:44
      kernel: WARNING: R/W mount of / denied. Filesystem is not clean - run fsck
      Jan 30 02:53:44
      Jan 30 02:53:44
      kernel: WARNING: / was not properly dismounted
      Jan 30 02:53:44
      kernel: Trying to mount root from ufs:/dev/ad0s1a
      Jan 30 02:53:44
      Jan 30 02:53:44
      Jan 30 02:53:44
      kernel: ad0: 1953MB <sandisk sdcfx3-2048="" hdx="" 4.08="">at ata0-master PIO4
      Jan 30 02:53:44
      kernel: hptrr: no controller detected.
      Jan 30 02:53:44
      kernel: Fast IPsec: Initialized Security Association Processing.
      Jan 30 02:53:44
      kernel: Timecounters tick every 1.000 msec
      Jan 30 02:53:44
      kernel: Timecounter "TSC" frequency 1830014380 Hz quality 800
      Jan 30 02:53:44
      kernel: vga0: <generic isa="" vga="">at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
      Jan 30 02:53:44
      kernel: sc0: VGA <16 virtual consoles, flags=0x300>
      Jan 30 02:53:44
      kernel: sc0: <system console="">at flags 0x100 on isa0
      Jan 30 02:53:44
      kernel: ppc0: [ITHREAD]
      Jan 30 02:53:44
      kernel: ppc0: [GIANT-LOCKED]
      Jan 30 02:53:44
      kernel: ppi0: <parallel i="" o="">on ppbus0
      Jan 30 02:53:44
      kernel: lpt0: Interrupt-driven port
      Jan 30 02:53:44
      kernel: lpt0: <printer>on ppbus0
      Jan 30 02:53:44
      kernel: plip0: <plip network="" interface="">on ppbus0
      Jan 30 02:53:44
      kernel: ppbus0: [ITHREAD]
      Jan 30 02:53:44
      kernel: ppbus0: <parallel port="" bus="">on ppc0
      Jan 30 02:53:44
      kernel: ppc0: FIFO with 16/16/16 bytes threshold
      Jan 30 02:53:44
      kernel: ppc0: SMC-like chipset (ECP/EPP/PS2/NIBBLE) in COMPATIBLE mode
      Jan 30 02:53:44
      kernel: ppc0: <parallel port="">at port 0x378-0x37f irq 7 on isa0
      Jan 30 02:53:44
      kernel: atkbd0: [ITHREAD]
      Jan 30 02:53:44
      kernel: atkbd0: [GIANT-LOCKED]
      Jan 30 02:53:44
      kernel: kbd0 at atkbd0
      Jan 30 02:53:44
      kernel: atkbd0: <at keyboard="">irq 1 on atkbdc0
      Jan 30 02:53:44
      kernel: atkbdc0: <keyboard controller="" (i8042)="">at port 0x60,0x64 on isa0
      Jan 30 02:53:44
      kernel: orm0: <isa option="" roms="">at iomem 0xd0000-0xd17ff,0xd2000-0xd2fff pnpid ORM0000 on isa0
      Jan 30 02:53:44
      kernel: pmtimer0 on isa0
      Jan 30 02:53:44
      kernel: sio1: [FILTER]
      Jan 30 02:53:44
      kernel: sio1: type 16550A
      Jan 30 02:53:44
      kernel: sio1: <16550A-compatible COM port> port 0x2f8-0x2ff irq 3 on acpi0
      Jan 30 02:53:44
      kernel: sio0: [FILTER]
      Jan 30 02:53:44
      kernel: sio0: type 16550A
      Jan 30 02:53:44
      kernel: sio0: <16550A-compatible COM port> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
      Jan 30 02:53:44
      kernel: speaker0: <pc speaker="">port 0x61 on acpi0
      Jan 30 02:53:44
      kernel: vgapci0: <vga-compatible display="">mem 0xe9000000-0xe9ffffff,0xd0000000-0xdfffffff,0xea000000-0xeaffffff irq 19 at device 0.0 on pci3
      Jan 30 02:53:44
      kernel: pci3: <acpi pci="" bus="">on pcib2
      Jan 30 02:53:44
      kernel: pcib2: <acpi pci-pci="" bridge="">at device 30.0 on pci0
      Jan 30 02:53:44
      kernel: ata1: [ITHREAD]
      Jan 30 02:53:44
      kernel: ata1: <ata 1="" channel="">on atapci1
      Jan 30 02:53:44
      kernel: ata0: [ITHREAD]
      Jan 30 02:53:44
      kernel: ata0: <ata 0="" channel="">on atapci1
      Jan 30 02:53:44
      kernel: atapci1: <nvidia nforce2="" udma133="" controller="">port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xf000-0xf00f at device 9.0 on pci0
      Jan 30 02:53:44
      kernel: ata3: [ITHREAD]
      Jan 30 02:53:44
      kernel: ata3: <ata 1="" channel="">on atapci0
      Jan 30 02:53:44
      kernel: ata2: [ITHREAD]
      Jan 30 02:53:44
      kernel: ata2: <ata 0="" channel="">on atapci0
      Jan 30 02:53:44
      kernel: atapci0: [ITHREAD]
      Jan 30 02:53:44
      kernel: atapci0: <sii 3112="" sii="" sata150="" controller="">port 0x9400-0x9407,0x9800-0x9803,0x9c00-0x9c07,0xa000-0xa003,0xa400-0xa40f mem 0xed004000-0xed0041ff irq 18 at device 11.0 on pci1
      Jan 30 02:53:44
      kernel: skc0: [ITHREAD]
      Jan 30 02:53:44
      kernel: e1000phy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseTX-FDX, auto
      Jan 30 02:53:44
      kernel: e1000phy0: <marvell 88e1011="" gigabit="" phy="">PHY 0 on miibus1
      Jan 30 02:53:44
      kernel: miibus1: <mii bus="">on sk0
      Jan 30 02:53:44
      kernel: sk0: Ethernet address: 00:11:2f:b8:e3:a5
      Jan 30 02:53:44
      kernel: sk0: <marvell semiconductor,="" inc.="" yukon="">on skc0
      Jan 30 02:53:44
      kernel: skc0: Marvell Yukon Lite Gigabit Ethernet rev. A3(0x7)
      Jan 30 02:53:44
      kernel: skc0: <marvell gigabit="" ethernet="">port 0x9000-0x90ff mem 0xed000000-0xed003fff irq 17 at device 4.0 on pci1
      Jan 30 02:53:44
      kernel: pci1: <acpi pci="" bus="">on pcib1
      Jan 30 02:53:44
      kernel: pcib1: <acpi pci-pci="" bridge="">at device 8.0 on pci0
      Jan 30 02:53:44
      kernel: nfe0: [FILTER]
      Jan 30 02:53:44
      kernel: nfe0: Ethernet address: 00:11:2f:b9:00:ef
      Jan 30 02:53:44
      kernel: rlphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
      Jan 30 02:53:44
      kernel: rlphy0: <rtl8201l 10="" 100="" media="" interface="">PHY 1 on miibus0
      Jan 30 02:53:44
      kernel: miibus0: <mii bus="">on nfe0
      Jan 30 02:53:44
      kernel: nfe0: <nvidia nforce2="" mcp2="" networking="" adapter="">port 0xcc00-0xcc07 mem 0xee004000-0xee004fff irq 20 at device 4.0 on pci0
      Jan 30 02:53:44
      kernel: uhub2: 6 ports with 6 removable, self powered
      Jan 30 02:53:44
      kernel: uhub2: <nvidia 1="" 9="" ehci="" root="" hub,="" class="" 0,="" rev="" 2.00="" 1.00,="" addr="">on usb2
      Jan 30 02:53:44
      kernel: usb2: USB revision 2.0
      Jan 30 02:53:44
      kernel: usb2: <nvidia nforce2="" usb="" 2.0="" controller="">on ehci0
      Jan 30 02:53:44
      kernel: usb2: companion controllers, 4 ports each: usb0 usb1
      Jan 30 02:53:44
      kernel: usb2: EHCI version 1.0
      Jan 30 02:53:44
      kernel: ehci0: [ITHREAD]
      Jan 30 02:53:44
      kernel: ehci0: [GIANT-LOCKED]
      Jan 30 02:53:44
      kernel: ehci0: <nvidia nforce2="" usb="" 2.0="" controller="">mem 0xee003000-0xee0030ff irq 22 at device 2.2 on pci0
      Jan 30 02:53:44
      kernel: uhub1: 3 ports with 3 removable, self powered
      Jan 30 02:53:44
      kernel: uhub1: <nvidia 1="" 9="" ohci="" root="" hub,="" class="" 0,="" rev="" 1.00="" 1.00,="" addr="">on usb1
      Jan 30 02:53:44
      kernel: usb1: USB revision 1.0
      Jan 30 02:53:44
      kernel: usb1: <ohci (generic)="" usb="" controller="">on ohci1
      Jan 30 02:53:44
      kernel: usb1: OHCI version 1.0, legacy support
      Jan 30 02:53:44
      kernel: ohci1: [ITHREAD]
      Jan 30 02:53:44
      kernel: ohci1: [GIANT-LOCKED]
      Jan 30 02:53:44
      kernel: ohci1: <ohci (generic)="" usb="" controller="">mem 0xee002000-0xee002fff irq 21 at device 2.1 on pci0
      Jan 30 02:53:44
      kernel: uhub0: 3 ports with 3 removable, self powered
      Jan 30 02:53:44
      kernel: uhub0: <nvidia 1="" 9="" ohci="" root="" hub,="" class="" 0,="" rev="" 1.00="" 1.00,="" addr="">on usb0
      Jan 30 02:53:44
      kernel: usb0: USB revision 1.0
      Jan 30 02:53:44
      kernel: usb0: <ohci (generic)="" usb="" controller="">on ohci0
      Jan 30 02:53:44
      kernel: usb0: OHCI version 1.0, legacy support
      Jan 30 02:53:44
      kernel: ohci0: [ITHREAD]
      Jan 30 02:53:44
      kernel: ohci0: [GIANT-LOCKED]
      Jan 30 02:53:44
      kernel: ohci0: <ohci (generic)="" usb="" controller="">mem 0xee001000-0xee001fff irq 20 at device 2.0 on pci0
      Jan 30 02:53:44
      kernel: pci0: <serial bus,="" smbus="">at device 1.1 (no driver attached)
      Jan 30 02:53:44
      kernel: isa0: <isa bus="">on isab0
      Jan 30 02:53:44
      kernel: isab0: <pci-isa bridge="">at device 1.0 on pci0
      Jan 30 02:53:44
      kernel: pci0: <memory, ram="">at device 0.5 (no driver attached)
      Jan 30 02:53:44
      kernel: pci0: <memory, ram="">at device 0.4 (no driver attached)
      Jan 30 02:53:44
      kernel: pci0: <memory, ram="">at device 0.3 (no driver attached)
      Jan 30 02:53:44
      kernel: pci0: <memory, ram="">at device 0.2 (no driver attached)
      Jan 30 02:53:44
      kernel: pci0: <memory, ram="">at device 0.1 (no driver attached)
      Jan 30 02:53:44
      kernel: agp0: <nvidia nforce2="" agp="" controller="">on hostb0
      Jan 30 02:53:44
      kernel: Correcting nForce2 C1 CPU disconnect hangs
      Jan 30 02:53:44
      kernel: pci0: <acpi pci="" bus="">on pcib0
      Jan 30 02:53:44
      kernel: pcib0: <acpi host-pci="" bridge="">port 0xcf8-0xcff on acpi0
      Jan 30 02:53:44
      kernel: acpi_button0: <power button="">on acpi0
      Jan 30 02:53:44
      kernel: cpu0: <acpi cpu="">on acpi0
      Jan 30 02:53:44
      kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x4008-0x400b on acpi0
      Jan 30 02:53:44
      kernel: Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
      Jan 30 02:53:44
      kernel: acpi0: reservation of 100000, 7fef0000 (3) failed
      Jan 30 02:53:44
      kernel: acpi0: reservation of 0, a0000 (3) failed
      Jan 30 02:53:44
      kernel: acpi0: Power Button (fixed)
      Jan 30 02:53:44
      kernel: acpi0: [ITHREAD]
      Jan 30 02:53:44
      kernel: acpi0: <nvidia awrdacpi="">on motherboard
      Jan 30 02:53:44
      kernel: cryptosoft0: <software crypto="">on motherboard
      Jan 30 02:53:44
      kernel: hptrr: HPT RocketRAID controller driver v1.1 (Jan 8 2009 22:07:11)
      Jan 30 02:53:44
      kernel: ath_hal: 0.9.20.3 (AR5210, AR5211, AR5212, RF5111, RF5112, RF2413, RF5413)
      Jan 30 02:53:44
      kernel: kbd1 at kbdmux0
      Jan 30 02:53:44
      kernel: wlan: mac acl policy registered
      Jan 30 02:53:44
      kernel: ioapic0 <version 1.1="">irqs 0-23 on motherboard
      Jan 30 02:53:44
      kernel: ACPI APIC Table: <nvidia awrdacpi="">Jan 30 02:53:44
      kernel: mptable_probe: MP Config Table has bad signature: 4
      Jan 30 02:53:44
      kernel: avail memory = 2091716608 (1994 MB)
      Jan 30 02:53:44
      kernel: real memory = 2147418112 (2047 MB)
      Jan 30 02:53:44
      kernel: AMD Features=0xc0400800 <syscall,mmx+,3dnow!+,3dnow!>Jan 30 02:53:44
      kernel: Features=0x383fbff <fpu,vme,de,pse,tsc,msr,pae,mce,cx8,apic,sep,mtrr,pge,mca,cmov,pat,pse36,mmx,fxsr,sse>Jan 30 02:53:44
      kernel: Origin = "AuthenticAMD" Id = 0x6a0 Stepping = 0
      Jan 30 02:53:44
      kernel: CPU: AMD Athlon(tm) XP 2500+ (1830.01-MHz 686-class CPU)
      Jan 30 02:53:44
      kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
      Jan 30 02:53:44
      kernel: sullrich@freebsd7-releng_1_2_1.pfsense.org:/usr/obj.pfSense/usr/src/sys/pfSense.7
      Jan 30 02:53:44
      kernel: FreeBSD 7.0-RELEASE-p8 #0: Thu Jan 8 22:07:30 EST 2009
      Jan 30 02:53:44
      kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
      Jan 30 02:53:44
      kernel: The Regents of the University of California. All rights reserved.
      Jan 30 02:53:44
      kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
      Jan 30 02:53:44
      kernel: Copyright (c) 1992-2008 The FreeBSD Project.
      Jan 30 02:53:44
      syslogd: kernel boot file is /boot/kernel/kernel
       w</fpu,vme,de,pse,tsc,msr,pae,mce,cx8,apic,sep,mtrr,pge,mca,cmov,pat,pse36,mmx,fxsr,sse></syscall,mmx+,3dnow!+,3dnow!></nvidia></version></software></nvidia></acpi></power></acpi></acpi></nvidia></memory,></memory,></memory,></memory,></memory,></pci-isa></isa></serial></ohci></ohci></nvidia></ohci></ohci></nvidia></nvidia></nvidia></nvidia></nvidia></mii></rtl8201l></acpi></acpi></marvell></marvell></mii></marvell></sii></ata></ata></nvidia></ata></ata></acpi></acpi></vga-compatible></pc></isa></keyboard></at></parallel></parallel></plip></printer></parallel></system></generic></sandisk>
      //Thanks in advance! :)
