    Multi wan weights and Speed Caps
    2 Posts 2 Posters 670 Views 2 Watching
      trumee
      Hello,
      I am trying to setup multi wan for two connection. The ISP have fair usage policy and the speed get throttled after the bandwidth caps are reached. Is there any way to handle this in pfSense? Can the weights be changed dynamically by monitoring the bandwidth used?
      • DerelictD Offline
        Derelict LAYER 8 Netgate
        No. That capability does not exist. You will have to manually monitor and disable the gateway when the cap is reached.
        Chattanooga, Tennessee, USA
