    Problem with Static ARP entry for VLAN/Virtual Interface
    4 Posts 3 Posters 701 Views 3 Watching
      joelones
      Not sure if someone could chime here in, I'm experiencing an odd issue after upgrading to Mac OSX 10.13.6 - it's propabably more of a networking question, sorry not sure where else to post.
      Let me explain, on my Mac OS X box I've created a Virtual Interface and gave it an IP 192.168.10.90 in the VLAN10 subnet ( the switch port of my Mac OSX is trunked to VLAN10 as well so I have both untagged and VLAN10 going through one cable, reason being I don't have another free port on my switch ).
      Furthermore, my Parellels Linux VM 192.168.10.20 (on my Mac OS X box) is bridged on that virtual interface and is given an address on VLAN10 via pfSense's DHCP.
      On the pfSense side of things for VLAN10, in the DHCP settings I have "Enable Static ARP entries" checked, and I statically assign IPs here based on MAC addresses, including this VM and its MAC address. Prior to the Mac OS X upgrade all worked fine where I had entered the MAC address of the VM in the DHCP settings.
      After the change, I now noticed that from the VM, I cannot access pfSense ( hence the internet ) but if I uncheck "Enable Static ARP entries" it works. I'd like to keep that option on, so I putzed and noticed if I enter the MAC address of the NIC of the Mac OS X box it works but no longer works with the MAC address of the VM ( which is a bit baffling as it was working before ).
      More so, when looking at the pfSense's ARP table, 192.168.10.20 has the Mac OS X NIC's MAC address not the VM's.
      I'm not sure what happened or whether it was the Apple update or my mind playing games on me or whether this is the intended behaviour when it comes to bridged adapters - which I doubt. Any thought would be greatly appreciated.
      • stephenw10S Online
        That looks like a change in OSX or in parallels.
        If pfSense is seeing a different MAC address it can't really be anything else.
          marvosa
          @joelones said in Problem with Static ARP entry for VLAN/Virtual Interface:
          Please clarify... cause none of this sounds right
            joelones @marvosa
            @marvosa said in Problem with Static ARP entry for VLAN/Virtual Interface:
            What I meant to say, was the the port of the netgear switch on which my Mac OS X box is connected allows untagged as well as VLAN 10 traffic to pass.
            But I suspect the Mac OS X update did something to affect this behaviour as it was working fine before the update and pfSense saw the VM's MAC address now it does not.
