    Lot of problems since Adding Static Routing for a VM Network, no problems when using OVPN...
    2 Posts 2 Posters 326 Views 2 Watching
    • B
      bfnti
      Hello,
      first I will show you my setup before explaining my problem:
      Interfaces:
      WAN
      LAN: 10.10.1.1
      Networks:
      LAN: 10.10.1.0/24
      OVPN: 10.10.2.0/24
      VMNET: 10.10.3.0/24
      Gateway for 10.10.3.0/24 is 10.10.1.10 (Using the Lan Interface)
      I have my firewall set up behind my Internet Router. And connected to 2 Cisco Switches 2x24
      connected to one of this switches is the VMNET Host server with the IP 10.10.1.10 which has the internal VMNetwork. I added Static routing and everything worked fine! But now here comes the problmes I dont know if it is because of the Static Gateway for the VMNET or something else but I get random lots of disconnects from my vmnet also I started getting disconnects in my normal Lan network from remote sites which are connected via IPSec (Before it worked fine...) when I use my OpenVPN Client I do not have those problems! So what is the best way to analyize this Problem?
      Thanks for any support :)
      1 Reply Last reply
      Reply Quote 0
      • M
        marvosa
        Can you provide a network map so we can see how things are connected?
        1 Reply Last reply
        Reply Quote 0
        Register Login
