Need some help with PFsense and Edgerouter X routing
im trying to learn how to do some local network routing so yes I'm doing this the hard way. I'm running pfdense as my primary router/firewall, dns, dhcp and I'd like to put some vlans into the mix if I can get the basics running like I want. currently I have a switch were I have my LAN but I'd like to turn into a DMZ zone for some servers and what ever. Then I have a Edgerouter X(ERX) that I'd like to put a user LAN on its own VLAN.
Then problem I'm having is that I can't get the ERX to route correctly, would rather not run NAT because I'd like to learn some firewall rules to control the traffic and I'd like to run this like a large LAN.
I can get out the internet with pfsense and I can ping the eth0 interface on the ERX but i cant get out from the EDX.
This is the conf from the EDX:
interfaces {
ethernet eth0 {
address dhcp
duplex auto
ip {
ospf {
network broadcast
speed auto
vif 10 {
disable
ethernet eth1 {
description Local
duplex auto
speed auto
ethernet eth2 {
description Local
duplex auto
speed auto
ethernet eth3 {
description Local
duplex auto
speed auto
ethernet eth4 {
description Local
duplex auto
speed auto
loopback lo {
switch switch0 {
address 192.168.10.34/27
description Local
switch-port {
interface eth1 {
interface eth2 {
interface eth3 {
interface eth4 {
port-forward {
auto-firewall enable
hairpin-nat disable
wan-interface eth0
protocols {
ospf {
area 0 {
area-type {
normal
network 192.168.10.32/27
network 192.168.1.0/24
parameters {
router-id 192.168.1.2
passive-interface default
passive-interface-exclude efh0
service {
dhcp-server {
disabled false
hostfile-update disable
shared-network-name LAN {
authoritative enable
subnet 192.168.10.32/27 {
default-router 192.168.10.34
dns-server 192.168.10.34
lease 86400
start 192.168.10.37 {
stop 192.168.10.62
dns {
forwarding {
cache-size 150
listen-on switch0
gui {
https-port 443
nat {
rule 5010 {
description "masquerade for WAN"
disable
log disable
outbound-interface eth0.1
protocol all
type masquerade
ssh {
port 22
protocol-version v2
system {
host-name ubnt
login {
user ************ {
authentication {
encrypted-password ****************
level admin
ntp {
server 0.ubnt.pool.ntp.org {
server 1.ubnt.pool.ntp.org {
server 2.ubnt.pool.ntp.org {
server 3.ubnt.pool.ntp.org {
syslog {
global {
facility all {
level notice
facility protocols {
level debug
time-zone UTC
