    How to Configure 2 WAN port - 1 WAN for for 60 Users & 2 WAN port for 20 Users
    6 Posts 4 Posters 858 Views 4 Watching
    • slkamathS Offline
      slkamath
      Hi
      Myself Lokesh Kamath.
      How to configure 2 WAN Ports (2 Different ISP's)?
      1st WAN port for 60 Users Internet / Mail Access
      2nd WAN port for 20 Users Internet / Mail Access
      Thanks in advance.
      Thanks & Regards
      Lokesh Kamath
      • JKnottJ Offline
        JKnott
        While it's entirely possible to connect to 2 ISPs, only 1 would normally be used. Also, how do you propose splitting the users into the 2 groups? You'd need 2 instances of pfSense, 1 for each ISP and VLANs or separate networks for each group.
        UniFi AC-Lite access point
        slkamathS 1 Reply Last reply Reply Quote 0
        • slkamathS Offline
          slkamath @JKnott
          @jknott
          Thank you for your response.
          In one pfSense we can not do it?
          • bootableB Offline
            bootable
            You can do it, using gateways groups, and rules with alias list, then create a rule on the internal interface and put alias_group_a as origin, destination any, gateway group gateway_isp_a, same thing with gateway_isp_b and alias_group_b.
            NOT NED A 2 INSTANCE OF PFSENSE..
            also you can cross redundace to both rules with the both gateway groups as failover with the 2 isp left aligned paragraph
            It is me Ruben
            Bootable Computación - Argentina.
            pfSense/Netgate Certificate Partner
            Pardon for my English - I am not an English speaker.
            Thanks a lot for yours invaluable time.
              Yes, that^
              Use policy based routing to send one group of users via one gateway (or gateway group).
              https://www.netgate.com/docs/pfsense/book/multiwan/multi-wan-terminology-and-concepts.html#policy-routing
              In order to separate those users into a different group you will need to use static DHCP leases (or static IPs) to be sure an alias containing their IPs always matches them.
              slkamathS 1 Reply Last reply Reply Quote 1
              • slkamathS Offline
                slkamath @stephenw10
                @stephenw10 @bootable
                Thank you.
                Very sorry for late response.
                Currently I cant try because We have only 1 ISP and second ISP we are yet to buy. So I understood that I can use Gateway Group and with 1 Instance I can use 2 ISP Gateways.
                May be with in 1 month we will procure 2nd ISP and I will ask any queries at that moment.
                Thank you once again.
                Lokesh Kamath
