Site-to-Site OpenVPN Connectivity Problem
It's not about ports but addresses/networks. They all need to be unique.
they are; screenshot below.
what would be the next think i try that you would suggest?
Don't know. I asked for some files in chat. Did you upload those?
Done. Thanks for taking a look at it!
Just wanted to check in if you had to review the files i sent over.
Thanks in advance!
guess not, no problem. thanks for giving it a shot, i do appreciate it.
Just as an update... I thought... well maybe it's one of the packages that's interfering with the traffic... so I've set up a completely vanilla lab on the vmware workstation. The only package loaded on both sides is open-vm-tools....
Same exact results.... so it makes me think i'm doing something wrong. I'll keep picking at it....
Any other suggestions are welcome.
I kind of gave up on the openvpn and went with IPsec... seemed to work as expected on the first try.
