    LAN overlap problem between work VPN and home LAN
    9 Posts 4 Posters 1.1k Views 4 Watching
      cobrahead
      I am trying to figure out the best way to solve a LAN overlap issue. My case involves connecting to a network at my office via VPN. The LAN at work is on the same subnet as I am on at home... 192.168.1.xxx... and that is causing issues, mainly the 'not working at all' issue.
      The VPN connection is using L2TP. This is something which is configured by my employer's IT company. My options are make it work with your home network or, no... that is my only option.
      What can I do to put (at least) one PC located on my home network onto a 'non-conflicting' subnet? I don't care if I have to manually go and 'flip a switch' in the Pf gui (or some similiar routine) in order to route the home PC to something that will work with my work.
      Thanks!
      "PERFECTION IS THE ENEMY OF PERFECTLY ADEQUATE."
        Napsterbater @cobrahead
        @cobrahead why not just change the whole LAN subnet to anything else in the 192.168.xxx.xxx or 10.xxx.xxx.xxx or even the 172.16-31.xxx.xxx range.
          cobrahead @Napsterbater
          @napsterbater said in LAN overlap problem between work VPN and home LAN:
          That would work. I just imagined it would be a cluster to do. How would I go about changing the entire range on an active LAN?
          • JKnottJ Offline
            JKnott @cobrahead
            @cobrahead said in LAN overlap problem between work VPN and home LAN:
            Change the LAN address and DHCP addresses.
            BTW, I ran into the same problem years ago, when I did a lot of travelling for work. I'd find myself in a hotel that conflicted with my home network. I moved my network to the 172.16.x.y range, as I have never seen anything in that range used elsewhere.
            UniFi AC-Lite access point
            A C 2 Replies Last reply Reply Quote 1
              akuma1x @JKnott
              @jknott said in LAN overlap problem between work VPN and home LAN:
              The easiest way to do this, in my opinion, because I've been in the same situation as you guys, is to change the LAN IP address range and DHCP addresses from a console or SSH connection. Don't try to do it thru the webgui on the LAN interface, it will flip out as soon as the IP address range is updated/changed. Or, if you've got a management interface setup, update the LAN settings thru here.
              Like @JKnott says, the 172.16.0.0/12 range is a good one. I don't bump into that one too many times, out in the wild, myself.
              Jeff
                cobrahead @JKnott
                @jknott said in [LAN overlap problem between work VPN and home LAN]
                @akuma1x said in [LAN overlap problem between work VPN and home LAN]
                I tried changing it from the console, but it flips out anyways. Should I use 172.16.0.0/12 as the LAN IP with a range of say, 1.1 - 1.254? I got the 172.16.x.x going enough that I could log into the web gui... and it showed the WAN as up and running, but I could not access the internet. I tried rebooting the Pf box and my PC ... I did not reboot my modem. Is there something I am missing?
                Thanks!
                  akuma1x @cobrahead
                  @cobrahead
                  What I did on mine was set LAN IPv4 to a static 172.16.0.1, subnet range to a /24. A range of /12 will give you over a million IP addresses to use internally on your LAN. That's probably too many, in this scenario. LOL
                  Then set the DHCP server on LAN starting at 172.16.0.2 to anything less than or equal to 172.16.0.254
                  You should be able to config all those settings thru the console or SSH, like I said. And, then, it wouldn't hurt to reboot all your gear, the modem too.
                  Jeff
                    cobrahead @akuma1x
                    @akuma1x said in LAN overlap problem between work VPN and home LAN:
                    @cobrahead
                    What I did on mine was set LAN IPv4 to 172.16.0.1, subnet range to a /24. A range of /12 will give you over a million IP addresses to use internally on your LAN. That's probably too many, in this scenario. LOL
                    Jeff
                    Will do, thanks for the pointers!
                      cobrahead @akuma1x
                      Jeff
                      That worked! I had one issue that involved changing some rules under the firewall section. Thanks again!
