    [Help] ntopng not displaying Minute Interface Top Talkers
    Scheduled Pinned Locked Moved Traffic Monitoring
    22 Posts 4 Posters 2.8k Views
    • M
      MrAmos123
      https://i.imgur.com/GnRG0Dh.png
      I cannot see the Minute Interface Top Talkers in Interfaces > Historical, this was visible in the previous version not too long ago.
      ntopng version via pfSense: 0.8.13_3
      ntopng version via ntopng: v3.4.180911
      Does anyone know how to amend this and return these values or is it bugged in the latest version of ntopng?
      • stephenw10S
        What pfSense version are you running? It looks like maybe a 2.4.5 snapshot?
        If so you should ask in development really.
        • M
          MrAmos123
          2.4.4-RELEASE (amd64)
          built on Thu Sep 20 09:03:12 EDT 2018
          FreeBSD 11.2-RELEASE-p3
          I believe I'm on the latest Stable build available.
          Any idea how I can fix ntopng? I have tried rebooting pfSense and restarting ntopng service, both didn't help. I don't want to clear ntopng's data in an attempt to fix it honestly as it's nearly a year's worth of data.
          • stephenw10S
            Weird my test box was only showing 0.8.13_2 available for some reason. Another box shows 0.8.13_3 which looks current.
            However I see ntopng Community Edition v.3.6.181102
            Your ntop version looks old for some reason.
            The 'Minute Interface Top Talkers' data does not appear immediately though. Do you not see it on any time-frame? I don't have enough data since I just installed to test it but I do see it on 5m after some time.
            • M
              MrAmos123
              Thanks for your reply again, but that's weird...
              I can't get v.3.6.X ever, I've never had it install v.3.6.X
              https://i.imgur.com/ECQejxQ.png
              https://i.imgur.com/E8UFJzS.png (pfSense Community Edition)
              I just tried reinstalling ntopng but that didn't do much honestly.
              And no, I can have it Historical data open for 20 minutes, on any timeframe tab and it will not display the Minute Interface Top Talkers.
              Any idea how to force ntopng to update to v.3.6X?
              EDIT: https://i.imgur.com/JVHTcBj.png Looking at dependencies and it does say "ntopng-3.6.d201800910,1", weird.
              • stephenw10S
                You don't see it as a dependency in the package manager?
                You might be able to pkg upgrade it from the command line but I'm not sure what effect that might have.
                3.4.X isn't even in our pkg repo so unless you have at some point added a different repo manually it's hard to explain how you have ended up with it.
                • M
                  MrAmos123
                  We commented at exactly the same time haha, see my edit. :)
                  ntopng-3.6.d201800910,1 is what I have and seems to match up with yours.
                  • stephenw10S
                    Hmm, maybe just something cached then. Try:
                    [2.4.4-RELEASE][admin@xtm800.stevew.lan]/root: pkg info -x ntopng
                    pfSense-pkg-ntopng-0.8.13_3
                    • johnpozJ
                      Hey stephenw10 are you saying 2.4.4 should see 8.13_3 in package manager?
                      I am seeing 13_2 as what is avail
                      GrimsonG 1 Reply Last reply Reply Quote 0
                      • GrimsonG
                        Grimson Banned @johnpoz
                        @johnpoz said in [Help] ntopng not displaying Minute Interface Top Talkers:
                        I see 8.13_3 on 2.4.4 CE on AMD64, I don't have an ARM device to check with. Try a "pkg update -f" on the console and look for error messages.
                        • stephenw10S
                          Yes. At least as far as I can see. Though I also saw 0.8.13_2 reported on one box.
                          Ah, that was only commited recently:
                          https://github.com/pfsense/FreeBSD-ports/commit/72bd65bb1fef00196770f734b78770236f591e17#diff-e5919fae5516fb0e52c4cfef76e364a1
                          And now I check it seems like it hasn't made it into the Factory repo yet. That's the difference between those boxes.
                          I'll see what's happening.
                          • M
                            MrAmos123
                            @stephenw10 it seems you're right, and it's cached for some odd reason.
                            [2.4.4-RELEASE][root@pfSense.local.lab]/root: pkg info -x ntopng
                            ntopng-3.4.d20180604,1
                            I'm unsure how to amend this unfortunately.
                            • stephenw10S
                              I would uninstall and then re-install the package (rather than re-installing directly). It should keep all the data as long as you still have Keep Data/Settings checked in the ntopng settings.
                              • M
                                MrAmos123
                                Okay, that amended the package version and installed the latest(?) v.3.6.181102, however, the same problem still exists where I'm unable to see Minute Interface Top Talkers... :(
                                https://i.imgur.com/QCOrQfh.png
                                • M
                                  MrAmos123
                                  Update; I took a snapshot beforehand but... I deleted all data, unchecked 'keep data' uninstalled, and reinstalled ntopng and it still does not have information displayed next to Minute Interface Top Talkers...
                                  https://i.imgur.com/AlK2ciN.png
                                  • stephenw10S
                                    Hmm, I'm not really sure how that feature is supposed to work. It's not something I ever use normally.
                                    It certainly seems a bit variable here. It doesn't always appear.
                                    It might be something that needs to go upstream to ntop.
                                    • M
                                      MrAmos123
                                      Weird, usually it just displays the machine with the highest bandwidth usage, I use it sometimes just to see who's the peak user at specific times, but it's not super important, just thought I'd share the issue.
                                      Please let me know if I can help in further testing.
                                      • M
                                        MrAmos123
                                        EDIT: It's now working??? https://i.imgur.com/dlH3bHA.png
                                        I didn't do anything, it just suddenly started working again since data wipe? uhh
                                        • stephenw10S
                                          Mmm, I have found it intermittent at best. No way to know what's happening there without digging much deeper.
                                          In previous versions that appeared immediately?
                                          • M
                                            MrAmos123
                                            I've never had any issues in 0.8.13_1, 0.8.13_2. I cannot tell you the specific ntopng versions unfortunately without a revision history to match those pfSense versions.
                                            But in these two revisions, it doesn't look like any changes were made in GitHub that should have interfered with my issue.
