latency of connection monitoring
Like most console games it's likely using p2p for multiplayer, which means one of the players is also the host. So latency will always vary, based on who is hosting the match and how their network holds up/is used. So if your connection is fine there is not much more you can do.
^ exactly!
@johnpoz said in latency of connection monitoring:
.02 to .04 ms??
WTF dude are you running? Never seen even lan ping times that low..
0.00003 seconds... Come on...
Are you pinging the boxes own IP? That is not really a test of network latency..
That is pfsense pinging itself.. Sure ok if that was high then something major wrong.. But that doesn't tell you how long it takes to get from pfsense to where your going and back ;)To PFSense
C:\Utilities\hrping>hrping -q -t -c 2 -s 0 192.168.1.1 This is hrPING v5.07.1148 by cFos Software GmbH -- http://www.cfos.de Source address is 192.168.1.2; using ICMP echo-request, ID=2c37 Pinging 192.168.1.1 [192.168.1.1] with 32 bytes data (60 bytes IP): [Aborting...] Packets: sent=32251, rcvd=32251, error=0, lost=0 (0.0% loss) in 1.444008 sec RTTs in ms: min/avg/max/dev: 0.001 / 0.072 / 1.346 / 0.015 Bandwidth in kbytes/sec: sent=1340.061, rcvd=1340.061Min of 0.001ms
To the first hop in my ISP
C:\Utilities\hrping>hrping -q -t -c 2 -s 0 x.x.x.x This is hrPING v5.07.1148 by cFos Software GmbH -- http://www.cfos.de Source address is 192.168.1.2; using ICMP echo-request, ID=ac40 Pinging x.x.x.x [x.x.x.x] with 32 bytes data (60 bytes IP): [Aborting...] Packets: sent=1181, rcvd=1179, error=0, lost=2 (0.1% loss) in 2.157322 sec RTTs in ms: min/avg/max/dev: 0.156 / 0.256 / 1.425 / 0.144 Bandwidth in kbytes/sec: sent=32.846, rcvd=32.790min 0.156ms
I assume the actual latency is lower, but I see packetloss from the host CPU of the core router not able to keep up.
You have to do ping floods to get really low measured latency because of CPU context switching. If you send one packet and block waiting, the kernel switching back to the thread takes a really long time relative to 1gb frame switching latency.
Like this 154us standard ping
C:\Utilities\hrping>hrping 192.168.1.1 This is hrPING v5.07.1148 by cFos Software GmbH -- http://www.cfos.de Source address is 192.168.1.2; using ICMP echo-request, ID=202e Pinging 192.168.1.1 [192.168.1.1] with 32 bytes data (60 bytes IP): From 192.168.1.1: bytes=60 seq=0001 TTL=64 ID=4234 time=0.282ms From 192.168.1.1: bytes=60 seq=0002 TTL=64 ID=4280 time=0.202ms From 192.168.1.1: bytes=60 seq=0003 TTL=64 ID=8788 time=0.154ms From 192.168.1.1: bytes=60 seq=0004 TTL=64 ID=bd93 time=0.167ms Packets: sent=4, rcvd=4, error=0, lost=0 (0.0% loss) in 1.501189 sec RTTs in ms: min/avg/max/dev: 0.154 / 0.201 / 0.282 / 0.049 Bandwidth in kbytes/sec: sent=0.159, rcvd=0.159Just look at this ping to localhost. It's nearly the same as targeting my gateway
C:\Utilities\hrping>hrping -q -t -c 2 -s 0 localhost This is hrPING v5.07.1148 by cFos Software GmbH -- http://www.cfos.de Source address is 127.0.0.1; using ICMP echo-request, ID=1c51 Pinging localhost [127.0.0.1] with 32 bytes data (60 bytes IP): [Aborting...] Packets: sent=1591, rcvd=1589, error=0, lost=0 (0.0% loss) in 0.055184 sec RTTs in ms: min/avg/max/dev: 0.001 / 0.030 / 0.468 / 0.018 Bandwidth in kbytes/sec: sent=1729.849, rcvd=1727.674PFSense: RTTs in ms: min/avg/max/dev: 0.001 / 0.072 / 1.346 / 0.015
Localhost: RTTs in ms: min/avg/max/dev: 0.001 / 0.030 / 0.468 / 0.018From what I can google, a context switch on a modern CPU is about 5us. Then you mix in the CPU trying to sleep and all that fun, you're left reading 200us.
@grimson Definitely. I am convinced that any latency will be out of my hands for more than the simple reason that it is part of the internet and that depends on the game provider (netcode and latency compensation model), but also because i do not really have the know how for it.
All i wish to know is when i am affected by higher latency so that i would leave a "bad" lobby for, possibly, a better one. -
Great then ping those - what is the latency..
sorry for the few hours hiatus. I did ping the above, however packets may be dropped as no ping back is received. I heard most game providers do that, probably to lessen the load on servers that i assume may be running at close to full capacity, and, in a conspiracy theory view.... to hide the fact that servers used may be in a different region or may not be as good as players expect them to be.. LOL.
The first reason much more likely.On PC, the game seems to run better and faster, plus ping is readily available and can be added as an overlay on a corner of the screen, but this is a whole different world.
