    Problem
    2 Posts 2 Posters 404 Views 2 Watching
    • X Offline
      xlameee
      hello
      I have problem and I don't know how to fix it
      I have done a quick map of my netowrk
      1st both WANs are static
      WAN1 - 10.91.8.1/16
      WAN2 - 10.88.88.5/28
      GW1 - 10.91.0.1
      GW2 - 10.88.88.1
      WAN1 is configured without problem but
      WAN2 when I plug the cable into a Switch C
      both getaways of the downstream network are going DOWN
      I have done this on my other SITE without a problem I feel like I am missing some pfsense settings for Dual WAN configuration ????
      Thank you
        cezp
        You might be getting a multicast flood, When you connect the cable to switch C, do you have constant traffic on the indicator? If so, then your vlans are bridged at two points and a loop is created.
