    PFSense 2.4.4 not responding at console and web interface CRITICAL BUG! HELP!
    32 Posts 3 Posters 3.8k Views 2 Watching
    • john_wickJ Offline
      john_wick @stephenw10
      Mostly yes. According to my observations, sometimes the calcru error enters the log not immediately, but at intervals after a pause. Basically, the console simply stops responding or responding via ssh and the web UI stops responding sometimes with a 502 bad gateway. Now I have installed sysctl kern.timecounter = ACPI-fast will reboot and look at the reaction. If I fail, I will try to improve performance and frequency.
        @stephenw10 said in PFSense 2.4.4 not responding at console and web interface CRITICAL BUG! HELP!:
        Sorry I missed a bit there, the sysctl should be kern.timecounter.hardware
        Did you try it at the command line first?
        Like this alt text Hase a diference with cli or with UI config edit?
          That's correct. It will apply via the GUI like that but it's then permanent. If you test it from the CLI first and it does something unexpected you can just reboot.
            john_wick
            Hi Stepen yesterday error is gone and server work stable access to cli and web UI was anytime when was small trafic but after night when trafic was zero error come back again. Need more time to watch on the actions and need to tweak to max performance or maybe I can add some cron jobs to prevent falling asleep webconfigurator or this is more fundamental timecounter problems?
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 685818 usec to 353871 usec for pid 24 (syncer)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 17 usec to 8 usec for pid 5 (sctp_iterator)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 18 usec to 9 usec for pid 5 (sctp_iterator)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 182 usec to 93 usec for pid 15 (usb)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 164420 usec to 83927 usec for pid 4 (cam)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 5 usec to 2 usec for pid 2 (crypto)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 19805 usec to 10109 usec for pid 14 (geom)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 21765 usec to 11109 usec for pid 14 (geom)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 1094 usec to 558 usec for pid 14 (geom)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 7510 usec to 3833 usec for pid 14 (geom)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 10 usec to 5 usec for pid 13 (ng_queue)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 15 usec to 8 usec for pid 13 (ng_queue)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 33 usec to 17 usec for pid 12 (intr)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 928 usec to 474 usec for pid 12 (intr)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 949204 usec to 490190 usec for pid 12 (intr)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 1790 usec to 1195 usec for pid 12 (intr)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 10823 usec to 5572 usec for pid 1 (init)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 20126323 usec to 10274286 usec for pid 1 (init)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 10 usec to 5 usec for pid 10 (audit)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 42471156539 usec to 21679250280 usec for pid 0 (kernel)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 7 usec to 3 usec for pid 0 (kernel)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 13 usec to 6 usec for pid 0 (kernel)
            Mar 25 15:08:27	kernel		calcru: runtime went backwards from 9 usec to 4 usec for pid 0 (kernel)
              kern.timecounter.hardware is still set to ACPI-fast?
              john_wickJ 1 Reply Last reply Reply Quote 0
                @stephenw10 Work stable last hours
                [2.4.4-RELEASE][root@pfSense.localdomain]/root: sysctl kern.timecounter
                kern.timecounter.tsc_shift: 1
                kern.timecounter.smp_tsc_adjust: 0
                kern.timecounter.smp_tsc: 0
                kern.timecounter.invariant_tsc: 0
                kern.timecounter.fast_gettime: 1
                kern.timecounter.tick: 1
                kern.timecounter.choice: i8254(0) ACPI-fast(900) HPET(950) TSC-low(800) dummy(-1000000)
                kern.timecounter.hardware: ACPI-fast
                kern.timecounter.alloweddeviation: 5
                kern.timecounter.stepwarnings: 0
                kern.timecounter.tc.i8254.quality: 0
                kern.timecounter.tc.i8254.frequency: 1193182
                kern.timecounter.tc.i8254.counter: 23746
                kern.timecounter.tc.i8254.mask: 65535
                kern.timecounter.tc.ACPI-fast.quality: 900
                kern.timecounter.tc.ACPI-fast.frequency: 3579545
                kern.timecounter.tc.ACPI-fast.counter: 12995060
                kern.timecounter.tc.ACPI-fast.mask: 16777215
                kern.timecounter.tc.HPET.quality: 950
                kern.timecounter.tc.HPET.frequency: 100000000
                kern.timecounter.tc.HPET.counter: 2672335151
                kern.timecounter.tc.HPET.mask: 4294967295
                kern.timecounter.tc.TSC-low.quality: 800
                kern.timecounter.tc.TSC-low.frequency: 1199698926
                kern.timecounter.tc.TSC-low.counter: 2441661706
                kern.timecounter.tc.TSC-low.mask: 4294967295
                  You could try the TSC-low timecounter also if you#re still seeing issues. That is lower quality though.
                    Last hours work stable :) Thank you for the professional help from expert its helps for my case!
                    Fought this problem for several months, there was no desire to leave PfSense.
                    This is my first experience with BSD systems. Several years watched pfsense and not in vain awesome project
                    What you mean That is lower quality though?
                    I have enother qestion about VM cputime (units) what optimal recomended value for PFsense in KVM?
                    Does it make sense to increase the frequency or processor time for more stable operation
                      The quality value shown in brackets denotes the accuracy of the timecounter source which is why HPET was chosen by default. That can be a problem when all the hardware is virtual, some may be virtualised better than others for whatever reason.
                      I can't really advice you on KVM settings directly. I would think anything that is different to the host CPU is going to require more processing from the hypervisor. Passing CPU cores directly to the VM is probably better. But as I say I don't use KVM so that's speculation. I'm sure there are others here who can give better advice there.
                        @stephenw10 Hi Stephen. UI and console was resopnsive after 15 hours and stable work
                          Cool. So which timecounter did you end up using for reference?
                            @stephenw10 I just add kern.timecounter.hardware=ACPI-fast from web UI in tunables and reboot the PFsense VM :)
