    NAT Reflection (timeout problem)
    30 Posts 7 Posters 18.2k Views
      sullrich
      Will consider the GUI option after I pass it by other devs.
      The patch was submitted to coreteam but had the potential to break QOS and Multi-Wan so it is not quite ready yet.  This is going from memory..  I am terribly sorry if I am confusing two different incidents.
        billm
        @sullrich:
        Why not just default it to 1 hour?  I'd rather not see yet another knob that people will twist for no good reason exposed.
        –Bill
        pfSense core developer
        blog - http://www.ucsecurity.com/
        twitter - billmarquette
          sullrich
          I am perfectly fine with this as long as no DOS potential is present?
          • F Offline
            firbc
            Question
            I see in blogspot that you change NAT reflection timeout to 2000 by default, so I decide to remove line <reflectiontimeout>2000</reflectiontimeout> (work with this line) from config.xml. I reboot my server machine and try connecting to battle.net (the way I testing nat reflection timeout) with 2 users on LAN.  After 20s LAN user joined in game has been disconnected.
            So question, am I need to install fresh copy of pfsense or is this normally and I just put those line back to config.xml?
            I using last version of pfsense 1.2 RC2 18.8.2007
            Thx
              sullrich
              You cannot simply remove the line.  It needs a value.
              • F Offline
                firbc
                As far as I see this line is optional and only change default value to value that you want. So I thought that now when default is 2000s line in config.xlm for reflection time out isn’t needed any more. Am I wrong?
                  sullrich
                  Yes, that is wrong.  If you do not want a timeout, set it to 0.
                  • F Offline
                    firbc
                    Ok and what is default timeout if there is no line in config.xml? I asking because you add that options in past »I added a hidden option for controlling this«.
                      sullrich
                      300 seconds IIRC.
                      • F Offline
                        firbc
                        Thx. for info.
