    (SOLVED) Problem with client connect through static IP cable internet
    54 Posts 6 Posters 15.5k Views 6 Watching
      paprikawuerzung
      Hello!
      we have the following setup:
      We're using the UnityMedia Business Cable Internet with a static IP.
      Now, with a quasi-default configuration of pfSense (which works nicely for our Telekom DSL), we are not able to get the internet working on the client side.
      pfSense has full connection to the internet (curl and everything works just fine) but all clients can not do layer-4 traffic.
      When doing ping 1.1.1.1, for example, the clients get nice results (same with traceroute). Doing curl google.de on the other hand does not work (the domain gets resolved by pfSense)
      Are there any additional configurations to be made?
      The gateway is set (and correct) on the WAN interface.
      Thanks a lot in advance for helping! Also hints would be greatly appreciated - if needed, I will provide additional screenshots/logs/... etc.
      • kiokomanK Offline
        kiokoman LAYER 8
        did you open port 53 on the lan side?
          paprikawuerzung
          Thanks for your reply!
          How would I do this? I have the automatic (default) Outbound NAT rules enabled which should cover the port opening/translation?
          I suspect it is a NAT/firewall issue since ping (layer-3) works, while layer-4 traffic (with ports) does not work at all on client side!
          • kiokomanK Offline
            kiokoman LAYER 8
            well you should check your firewall log to see if it really open the port under Status / system log / firewall
            you need to go to firewall / rules / LAN and add the desired rules
            for dns to work you need at least port 53
            to surf the web port 80 and 443
            and so on
            the default behavior of the firewall is to block everything
            this is just an example of how to do it
              paprikawuerzung
              Thanks again for the (fast) reply!
              Is this something specific to my static IP setup on WAN? Because when I use a PPPoE WAN configuration I do not need to open the ports manually - there, the configurations are done automatically and without problems at all!
              I will try your approach later on.
              • JeGrJ Offline
                JeGr LAYER 8 Moderator
                @paprikawuerzung said in Problem with client connect through static IP cable internet:
                pfSense has a default rule on LAN, allowing ANY traffic outbound to the internet. If you have that one still in place your problem is not layer 4/rules related. Your NAT is configured on automatic? How about showing the rules and outbound NAT settings as well as the WAN interface settings?
                  paprikawuerzung
                  Thanks again for your answers!
                  @JeGr said in Problem with client connect through static IP cable internet:
                  Yes, I have all defaults configurations in the Firewall/(outbound) NAT sections.
                  I am currently not on-premise. I will provide all screenshots later on. But as I said before: they are pretty standard!
                  • JeGrJ Offline
                    No problem. If there're indeed the defaults at work we'll have to check from the client up to the WAN to find the culprit here. That's why screens of WAN IF config, NAT outbound, firewall rules WAN/LAN and DNS resolver (unbound) config may be necessary. :)
                    • kiokomanK Offline
                      kiokoman LAYER 8
                      but when he wrote that "nslookup google.de 1.1.1.1" is not working that can only be because port 53 is closed somehow/somewhere,that's why i suggested to check firewall logs
                      anyway
                      we will wait for the screenshots
                      • maverickwsM Offline
                        maverickws
                        What kind of configuration are you using on DNS? Is it Resolver or Forward?
                        If on a local machine you dig google.de without any other options, which server do you query?
                        Viewing on your local machine, what DHCP DNS config is being passed to clients?
                        • JeGrJ Offline
                          @kiokoman said in Problem with client connect through static IP cable internet:
                          Nope, could also be a problem with unbound/dnsmasq (depending on wheter he uses forwarder or resolver) and how it is set up and configured. That's why I was asking about what DHCP settings are configured in another thread. If he pushes an external non-working DNS to the client, that would explain the broken setup. @maverickws question points into the same area :)
                          Greets
                            paprikawuerzung @JeGr
                            Wow, a lot of answers!
                            Greets
                            The DNS provided by DHCP to the client does not seem to be the problem! The client has 192.168.178.1 (pfSense) as DNS and pfSense in turn uses the DNS Forwarder (unbound) to resolve the domains (which works just fine).
                            The problem is: the clients are not able to make DNS queries themselves (= directly to 8.8.8.8 for example)! The gateway (192.168.178.1 - pfSense) is set correctly on the clients. But all connections with ports (layer 4) time out...
                            I strongly believe that this is a gateway/NAT/firewall problem - not a DHCP config problem at all. pfSense gets all the traffic from the clients - but somehow does not handle it correctly.
                            I will create a complete fresh install of pfSense, do minimal configuration (so that pfSense hat an internet connection through the cable) and will send screenshots in 3-4 hours!
                            maverickwsM 1 Reply Last reply Reply Quote 0
                              maverickws @paprikawuerzung
                              @paprikawuerzung
                              Hi there,
                              I don't think you have the correct configuration, and may I add I did this mistake recently of having forwarder mode enabled thus bypassing unbound.
                              btw, is 192.168.178.1 the pfSense?
                              If you go to Diagnostics > DNS Lookup you can resolve properly from the pfSense?
                              Basically if you are using DNS Resolver (unbound) you don't need to set any DNS servers (much less Google's, phew, try CloudFlare or OpenDNS), but anyway with this configuration you may set NONE.
                              The purpose of DNS Resolver is to query the ROOT DNS servers on the top of hierarchy.
                              For this you must disable the "enable forwarding mode" on DNS Resolver.
                              The DHCP will then pass the pfSense itself as DNS for your clients.
                              You can make queries via IP, but you cannot resolve IP's from names. That's DNS.
                                paprikawuerzung @maverickws
                                @maverickws said in Problem with client connect through static IP cable internet:
                                @paprikawuerzung
                                Hi there,
                                Yes, I can query everything without any problem. I am really, really, really sure that DNS is not the problem since HTTP and SSH (with some IP address) do not work (which does not have anything to do with name translation at all) on client side - but work without problems on pfSense (see diagram)...
                                I have 1.1.1.1 and 8.8.8.8 set in the general setup - they are used by unbound as far as I know. But as I said before: I do not think DNS is the problem - HTTP, SSH, ... all do not work from the client - but using "Diagnostics -> Command Prompt" on pfSense they work without problems.
                                I know what DNS is for and I also understand that there might be a problem with it - but also IP-based traffic (without domain names at all) do not work also - they all time out.
                                  maverickws
                                  When you say "HTTP, SSH all do not work from the client" in the example (diagram) you provided you have:
                                  curl google.de not working - still requires DNS to resolve google.de - sorry I didn't get from your previous posts that you were lacking connectivity when using IP addresses.
                                  I'm not about nslookup so I'll skip that one in particular.
                                  Anyway cause I gtg I'll leave my DNS Resolver config so you can compare to yours:
                                  DNS Resolver - General Settings
                                  Also, if you do a curl 216.58.211.35 what is the output?
                                  Do you have the default allow LAN to any rule on your firewall?
                                  Firewall > Rules > LAN
                                  • Action: Pass
                                  • Interface: LAN
                                  • Address Family: IPv4
                                  • Protocol: Any
                                  • Source: LAN Net
                                  • Destination: any
                                    Thanks for your answers again!
                                    Yes, nslookup google.de is working (eg. returns 172.217.21.227) on the client - so doing curl google.de or doing curl 172.217.21.227 results in the same behavior.
                                    Doing nslookup google.de 1.1.1.1 (ie. using Cloudflare 1.1.1.1 as the DNS server) on the client does not work. Same behaviour as with HTTP, SSH, ...
                                    Time-out on the client. Same with SSH. Works fine on pfSense (Diagnostics -> Command Prompt).
                                    • Action: Pass
                                    • Interface: LAN
                                    • Protocol: Any
                                    • Source: LAN Net
                                    • Destination: any
                                    I will have to look later - but the config is the default and I think it is there.
                                    I am really unsure what pfSense is doing with client traffic! Normally, I would assume it does outbound NAT (= gives traffic outside some temporary ports and writes its own (external) IP address in the SRC field) and does the translation backwards when the requests come back. But somehow in this chain, the packets get dropped... Is there a possibility to track all traffic (= testing NAT)?
                                      paprikawuerzung
                                      @maverickws @JeGr @kiokoman
                                      I found the solution: I had to add a firewall rule to allow OUT traffic from LAN -> WAN. Floating Rule...
                                      I am not entirely sure why this was necessary but I wanted to rule out any firewall involvement. All the traffic from the LAN net to the WAN net was silently blocked by pfSense.
                                      As I am not that familiar with firewall rules: is this a potential security risk?
                                      • KOMK Offline
                                        KOM
                                        Post a screencap of your LAN rules so we're not guessing what you've got going on. You should NOT need floating rules unless you're doing traffic shaping or a complex config. By default, LAN allows all traffic to anywhere.
                                          paprikawuerzung
                                          I currently do not have access to pfSense - I will post the screenshots tomorrow morning!
                                          Apart from that: thousand thanks for your help and time :)
                                            paprikawuerzung
