    (SOLVED) Problem with client connect through static IP cable internet
    54 Posts 6 Posters 10.8k Views 6 Watching
      paprikawuerzung
      This is my working config: config-pfSense.SCRUBBED.xml
      • KOMK Offline
        KOM
        Nobody wants to parse through an XML file. Screencaps are much better, a picture worth a thousand words etc.
          paprikawuerzung
          @KOM said in Problem with client connect through static IP cable internet:
          I am sorry but I am not on-premise. I only have the config here. But I'll try to create a VM, import the config and make screencaptures.
            paprikawuerzung
            @KOM
            Screenshot_2019-07-04 pfSense office patagona de - Interfaces WAN (em1).png Screenshot_2019-07-04 pfSense office patagona de - Firewall Rules LAN.png Screenshot_2019-07-04 pfSense office patagona de - Firewall Rules Floating Edit(1).png
            • KOMK Offline
              KOM
              Get rid of that floating rule. You don't need it and it may be part of the problem. If you lose connectivity after deleting that rule then there is a deeper problem to be discovered and fixed because, like I said earlier, floating rules are used for QoS and special custom configs. You don't need any floating rules to get basic connectivity working.
              Your LAN rules look good but there is no traffic logged (0/0 B for each rule) which means pfSense isn't seeing anything from LAN that is hitting those rules. The floating rule may be taking precedence.
              What specific errors are the clients getting when trying to connect using various things like ssh or http/s? The exact error text can be very helpful.
              P 1 Reply Last reply Reply Quote 1
              • maverickwsM Offline
                maverickws
                  paprikawuerzung @KOM
                  Just to be 100% clear on that: without the floating rule the clients are not able to access the internet. Even IP-based traffic (like ssh to an IP) is not possible without the floating rule. Pinging specific IPs works, everything else does not work.
                  With the floating rule, the internet and everything else works just perfectly.
                  It is 99% a firewall issue.
                  My setup is a fresh install of pfSense with only the static IP for the WAN interface and the floating rule added.
                  When the floating rule is NOT enabled: curl/ssh and everything like that simply times out. There are no specific error messages (only "Connecting to ....... Connection timed-out"). The error text is very non-descriptive.
                  I will provide the exact error messages after I have pfSense installed freshly (without the floating rule).
                    maverickws
                    The default LAN IPv4 allow to any rule does not belong on the floating, so something is wrong there.
                    Do you have other Floating rules?
                      paprikawuerzung
                      @maverickws said in Problem with client connect through static IP cable internet:
                      The default "LAN IPv4 allow" rule is unchanged from a fresh install (and also works when using my DSL internet through PPPoE on the WAN interface). But when using the static IP configuration for WAN this rule (for some reason) does not work (0/0B)...
                      This here is a screenshot of my DSL internet firewall rule (NOT the cable static-IP internet connection where the problem persists):
                      In this configuration for DSL with PPPoE, I do NOT have a floating rule - everything works fine.
                      • JeGrJ Offline
                        JeGr LAYER 8 Moderator
                        @paprikawuerzung said in Problem with client connect through static IP cable internet:
                        And to be clear on our side: a floating rule is NOT needed for proper functionality. IF things work only then, you have - as already said - a deeper problem or serious configuration flaw that you didn't see/show. As outbound rules are created automatically in the background, something definetly doesn't add up. Period.
                        As debugging is simply voodoo and guessing at the moment, you should gather information when you are back on site and post them. Even screens in the VM are void, as it's not the same constellation as on site with the WAN and a LAN client behind it to test.
                        I'd also double check DHCP settings and the client on premise: does it have the right IP address and does it match the LAN configuration? Not the first time there was a simple small problem in numbers that got switched around and as the default LAN rules are matched against "LAN net" instead of "any" a DHCP problem can go unnoticed as "firewall access works".
                        Traceroute from the Client helps checking if the packet goes the right way and if and where it hits the firewall to trigger routes and rules.
                        Don't forget to upvote ๐Ÿ‘ those who kindly offered their time and brainpower to help you!
                          paprikawuerzung
                          @JeGr said in Problem with client connect through static IP cable internet:
                          Yes, sorry for my tone in the previous posts. I am a little frustrated that at first every post was about DNS and DHCP when I already ruled that out 10 posts ago (for that matter I was sure that its not a problem before I even posted this thread) and I wanted it to be clear that it really, really is not the problem at all.
                          I know that you help me with your time and I am very grateful for that!
                          To the topic:
                          This is a complete fresh install with only the static IP and gateway for the WAN interface added. If it is a configuration problem it is part of pfSense as it (appearently) does NOT "create the outbound rules automatically in the background".
                          Since there are no definitive guides on how to configure static WAN IP setups (with UnityMedia/KabelBW) it is highly unclear whether this calls for floating rules or not. I read the sections in the pfSense regarding floating rules and understand that they are only used as a last resort - and that internet normally works out of the box with everything handled perfectly by pfSense - but this is obviously not the case.
                          The configuration (down to the IP addresses) is exactly the same so it is not completely void.
                          DHCP on client side works and the IPs, Gateway, Domain etc. are set correctly. I am very sure about that. It is not a configuration error in the DHCP area. Which also shows that when I add the floating rule (without re-requesting a DHCP lease) -> the internet works instantly - without any further configuration of the client or pfSense.
                          I will provide screenshots and outputs after I am at the premise again.
                          A thousand thanks again for your answers/guidance!
                          • JeGrJ Offline
                            Yes it is. In default configuration. Otherwise check /tmp/rules.debug for yourself and compare it with your DSL configuration.
                            Why should there? It's completely transparent. If you configure DHCP IP, static IP or PPPoE for exmaple don't matter at all what pfSense creates for automatic rules like automatic outbound rules, default LAN rules etc. It's essentially the same if you don't configure some highly experimental or advanced options on the Interfaces/WAN setup screen.
                            Yes in your case. In hundreds of others we configured/installed it does. Be it PPPoE, DHCP, static IP4. No matter what :)
                            Void for me as in "I can't help or debug with you when this is not the same environment the error happens and the virtual setup isn't configured exactly the same (as in: has some sort of uplink, a test VM as client behind it etc. etc.)". So for debugging the problem it's not really well suited :)
                              paprikawuerzung @JeGr
                              It is a complete fresh install with no firewalls added and no additional configuration made apart from adding the static IP. Whether this rule is created or not (I believe you if you say it is) does not make any difference as it does not work.
                              I also configured the PPPoE configuration without any problems at all. The only difference here is that I add a static IP (provided by UM) and a gateway (also provided by UM). Why this should create problems with the firewall is beyond my knowledge...
                              Ok. I will provide screenshots from the running system.
                              • KOMK Offline
                                KOM
                                https://docs.netgate.com/pfsense/en/latest/routing/connectivity-troubleshooting.html
                                It's always something from this list. I would do a packet capture on LAN to see if client packets are hitting the interface at all, and another on WAN to see if they're being forwarded out.
                                  paprikawuerzung
                                  I fixed the error by adding a WAN firewall rule. In the default installation, this rule was missing:
                                  I found the rule in another pfSense installation (= DSL internet) which I compared to the (now working) cable internet installation. After adding it, everything works just fine. The floating rule was overkill but essentially did the same thing.
                                  I am still a little confused why this rule was not created automatically (as it was in the PPPoE DSL installation). Also, there were strange issues when booting the Fritz!Box BEFORE booting pfSense - even with reboots. In the last installation, everything worked out just fine and with no hassle - strange, strange... But now everything seems to be working just as I want it to ๐Ÿ˜„
                                  Thousand thanks for your time and suggestions, @JeGr, @kiokoman, @KOM and @maverickws ! ๐Ÿ™‚
                                  • KOMK Offline
                                    KOM
                                    No, you still have a problem. You shouldn't have ANY rules on WAN except for Block RFC1918, and any port-forwards you have defined. You do NOT need a WAN rule to get Internet access from LAN. You have something weird going on with your installation or environment.
                                      paprikawuerzung
                                      @KOM said in (SOLVED) Problem with client connect through static IP cable internet:
                                      I am little frustrated by these comments suggesting the configuration is strange: my configuration (as I told at least 5 times) is done completely from a clean installation (factory reset on pfSense or even new installation). I only added (as I told at least 5 times) only the static IP (+ Gateway) given by UnityMedia and left everything apart from the (global) DNS servers (which arguably are really, really not the problem) as default.
                                      The Fritz!Box 6490 is factory reset (with IT'S public, static IP defined/put there by UnityMedia) and apart from disabling the WLAN, I did not change anything. This public, static IP defined in the Fritz!Box (and provided by UnityMedia) is my gateway in pfSense. This setup was suggested by three different technicians at UnityMedia and most likely is not the culprit.
                                      So, I would argue that my setup or configuration is not special in any strange way.
                                        paprikawuerzung
                                        I am not sure whether this helps but this is the output of /tmp/rules.debug
                                        (My added rule is in there also)
                                        • KOMK Offline
                                          KOM
                                          Wait, you have Snort installed?? I assumed that you were using a default config to get it going without installing any extra packages. If that is the case, please disable ALL packages that may interfere with traffic, such as Snort, Suricata, pfBlocker, squidguard.
                                          • chpalmerC Offline
                                            chpalmer
                                            @paprikawuerzung said in (SOLVED) Problem with client connect through static IP cable internet:
                                            Fritz!Box 6490
                                            Your modem is a Puma 6 powered model and AFAIC a piece of crap. But my guess is that you are stuck with it. (badmodems.com)
                                            That model is a gateway model and is still routing as opposed to true bridge mode.
                                            How many static addresses did they give you? The /30 surprises me a little.
