    Multi WAN traffic shaper problem(LOAD BALANCE)::
    3 Posts 3 Posters 593 Views 3 Watching
      krishan
      Hi
      I am using two ISP A&B for instance. Both are managed with load balancing and fail-over gateway and working fine, ISP A have 8 Mbps & ISP B have 40 Mbps. ISPA=WAN & ISPB OPT1 , and tier 1:1 for load balance on "high latency or packet loss" and tier 1:1 for fail over on "member down". and need to distribute it over 150 users. so how we achieve a proper bandwidth over every user. I tried to use Traffic shaper and Limiters with alias but din't worked out please help me to manage.
      • kiokomanK Offline
        kiokoman LAYER 8
        maybe if you read this it can help you
        https://forum.netgate.com/topic/48694/limit-bandwidth-per-ip
          If you WAN bandwidths are that different the first thing you should do is weight the gateways in the load-balance group so you get 5:1 connections using the ISP B gateway.
          Then a great way to set equal bandwidth per user is to use dynamic limiters based on a /32 mask.
          Unfortunately the screenshots have been lost from here:
          https://forum.netgate.com/topic/57476/per-ip-traffic-shaping-share-bandwith-evenly-between-ip-addresses
          The description is still good though.
