    Is there a way to trigger pfSense to periodically send RS on WAN I/F to ISP edge router?
    50 Posts 6 Posters 9.2k Views 6 Watching
      bimmerdriver @JKnott
      @JKnott said in Is there a way to trigger pfSense to periodically send RS on WAN I/F to ISP edge router?:
      @bimmerdriver said in Is there a way to trigger pfSense to periodically send RS on WAN I/F to ISP edge router?:
      According to the most recent email I got from the ISP, the CPE only accepts unsolicited RA with unicast destination address.
      That's nonsense. Unsolicited RAs only go to the multicast address. If they were only sent to the unicast address, how would the router know the unicast address of something that didn't send a request?
      I'm not going to post the email, but that's what I was told.
      • JKnottJ Offline
        JKnott @bimmerdriver
        Perhaps it's time to escalate. I find the first level support isn't much good for unusual problems, so I wind up asking for 2nd level right off. Even then, I had to explain how DHCPv6-PD worked to the tier 2 guy, including how the assigned address is not used for routing etc. I walked him through things to try, while I monitored with Packet Capture or Wireshark, tested through my cell phone and more. Then they guys who were responsible for fixing the problem refused, as I had my own equipment beyond the modem, even though the problem was proven to not be at my end. It took a lot of effort, but I finally got the problem resolved. You might have to do the same.
        What did that guy say about the RFC that shows how it's supposed to work?
        BTW, that book I quoted from is an excellent IPv6 reference.
        UniFi AC-Lite access point
          @JKnott I'm not going to dox my contact, but "that guy" is not in first or second or any other level of support. He is an engineer. It's not that he doesn't understand what the RFCs say, but rather that these issues reflect vendor-supplied cpe and edge routers and the respective vendors won't cooperate in a timely manner or at all to resolve them. If I disagree with anything he says, it's that these issues are being tolerated and in some cases accommodated, rather than being corrected.
          • JKnottJ Offline
            What happens with other customers? I doubt pfSense is the only router that has this issue. With that sort of attitude, perhaps it's time to find another ISP. I don't understand the point of offering a service that won't work with most of the devices out there. If you've been following here long enough, you're no doubt aware some providers have some strange ideas.
              ISPs usually hide behind the position that if you aren't using their equipment, they are not obligated to provide any support. This is what you would get from first or second level support from virtually any ISP in my experience. You have to admit that only a very small portion of the subscriber base is using anything other than the ISP-supplied CPE.
              As for switching ISPs, been there, done that. The only alternative is Shaw and they suck even more than Telus.
              DerelictD JKnottJ 2 Replies Last reply Reply Quote 0
              • DerelictD Offline
                Derelict LAYER 8 Netgate @bimmerdriver
                @bimmerdriver Seems they could un-disable unsolicited RAs to adhere to the standard and their devices could continue to operate outside the standard, send RSs, and get unicast RAs in response. Both should work in that case.
                Chattanooga, Tennessee, USA
                • JKnottJ Offline
                  I'm on Rogers and use their modem in bridge mode, with a computer running pfSense as my firewall/router. As I mentioned, the guys responsible for maintaining the network didn't want to do anything because I had my own router/firewall, even though I was able to prove the problem was not on my network and could even identify the failing system by name. On top of that, both tier 2 support and a senior tech verified it was a Rogers problem. It was only after the senior tech brought his own modem to my home, found it failed and then took it to the head end and tested with my CMTS and 3 others, but found it only failed with mine, that they finally got around to fixing the problem. If I hadn't stuck with it and even contacted the office of the president, it would likely not be fixed and this was a problem that affected everyone on my node. Since the engineer refuses to be compliant with the RFC, then I'd say escalate to upper management and let them know their engineer is refusing to be compliant with published Internet specifications. Perhaps contacting the CRTC or CCTS might be in order.
                    jdu-9999
                    @bimmerdriver were you ever able to figure out a solution for this? I'm assuming the ISP involved is Telus. They appear to be uninterested in changing this behaviour despite my attempts to point out they are not following the RFC. The only solution they've offered is to swap out the network hardware for one of their newer modems that ignores the RFC.
                      bimmerdriver @jdu-9999
                      @jdu-9999 You're correct, the ISP is Telus. To be honest, I had better things to do, so I basically gave up. I'm curious about who you talked to. Can we take this offline?
                        jdu-9999
                        It appears that if you add a cron job to run "/sbin/rtsol -a" once an hour it'll keep the IPv6 connection. I suspect someone read RFC 6275 and decided that "Router advertisements in such networks SHOULD be sent only when solicited" also applied to this network, despite it not technically being a mobile network. (Telus are also a mobile carrier, so it's possible this is where the confusion came from.)
