    Problems with Squid and SpamD
    20 Posts 10 Posters 10.1k Views
    • K
      KiaN
      Hi there  ;)
      I have a few problems with plugins,
      My version :
      RELENG_1_SNAPSHOT-06-24-2006
      built on Fri Jun 16 01:10:36 UTC 2006
      First of all, I'd like to use the Squid proxy, but I cant manage ton run the service, whenever I click on Star the service, I get Squid has been started but it never starts and is still shown as Stopped. I dont know how to make it work  :(
      I also would like SpamD to filter my mails with RBLs, and added external sources, but still the database says that it has 0 item in the blacklist, I cant manage to syncronize the black list with RBLs (I added SpamHaus and ORDB)
      I dont understand why ..
      I also wanted to add an entry as spamtrap, not knowing what it was, and now I cant remove it :
      SPAMTRAP 123@123.com
      1 Reply Last reply
      Reply Quote 0
      • K
        KiaN
        Ok I managed to run squid manually, first using squid -z to create squid swap. Now it seems to work …
        (and it went down ...)
        Edit :
        It still wont work for long, and I cant start the service from the GUI :(
        Ok I managed to run squid manually, first using squid -z to create squid swap. Now it seems to work ...
        Edit :
        Jul 2 15:07:01 squid[47274]: Squid Parent: child process 47297 exited due to signal 6
        Jul 2 15:07:04 squid[47274]: Squid Parent: child process 47307 started
        Jul 2 15:07:04 kernel: pid 47307 (squid), uid 62: exited on signal 6
        Jul 2 15:07:04 (squid): Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
        Jul 2 15:07:04 squid[47274]: Squid Parent: child process 47307 exited due to signal 6
        Jul 2 15:07:07 squid[47274]: Squid Parent: child process 47316 started
        Jul 2 15:07:07 kernel: pid 47316 (squid), uid 62: exited on signal 6
        Jul 2 15:07:07 (squid): Failed to verify one of the swap directories, Check cache.log for details. Run 'squid -z' to create swap directories if needed, or if running Squid for the first time.
        Jul 2 15:07:07 squid[47274]: Squid Parent: child process 47316 exited due to signal 6
        Jul 2 15:07:07 squid[47274]: Exiting due to repeated, frequent failures
        Jul 2 15:09:43 squid[47495]: Squid Parent: child process 47497 started
        Jul 2 15:11:35 squid[47692]: Squid Parent: child process 47694 started
        Jul 2 15:11:35 squid[47692]: Squid Parent: child process 47694 exited due to signal 15
        Jul 2 15:12:20 squid[48124]: Squid Parent: child process 48128 started
        Jul 2 15:12:46 squid[48274]: Squid Parent: child process 48276 started
        Jul 2 15:15:10 squid[48569]: Squid Parent: child process 48572 started
        Jul 2 15:16:18 squid[48792]: Squid Parent: child process 48794 started
        Jul 2 15:17:14 squid[49330]: Squid Parent: child process 49332 started
        Jul 2 15:21:50 squid[50118]: Squid Parent: child process 50120 started
        The transparent mode is activated but does not work.
        1 Reply Last reply
        Reply Quote 0
        • K
          KiaN
          Am i the only one to use or try to use SpamD ? (well, and Squid)
          1 Reply Last reply
          Reply Quote 0
          • H
            hadi57
            hi,
            i am in the same situation as u are regarding squid proxy server not starting, causing internet to be slow because i am not able to use upstream proxy as well.
            hadi57
            1 Reply Last reply
            Reply Quote 0
            • D
              dvserg
              run 'squid -z' in command prompt
              in log this recommended
              SquidGuardDoc EN  RU Tutorial
              Localization ru_PFSense
              1 Reply Last reply
              Reply Quote 0
              • S
                SatireWolf
                You have to do a cvsupdate update in RC1 to get squid to start correctly from the web page. Otherwise it won't start at all. It's a bug in RC1 pressed CD (haven't checked RC1a or the July 5th version that just came out, I'll give you an update in a few).
                1 Reply Last reply
                Reply Quote 0
                • K
                  KiaN
                  I have  RELENG_1_SNAPSHOT-07-03-2006
                  1 Reply Last reply
                  Reply Quote 0
                  • M
                    mrreload
                    I had the same problem getting Squid to start. Had to squid -z then reboot pfsense for it to start up properly. It still won't start from the GUI though.
                    1 Reply Last reply
                    Reply Quote 0
                    • C
                      Carlo
                      I am having the same issues with Squid. I can't start it from the GUI.
                      Any solution to this problem?
                      -carlo
                      1 Reply Last reply
                      Reply Quote 0
                      • S
                        SatireWolf
                        Do a cvs_sync.sh update… Seems to have fixed the problem for me a week or so ago.
                        1 Reply Last reply
                        Reply Quote 0
                        • H
                          hoba
                          If at all do a "cvs_sync.sh releng_1" !!! But be aware that this will be tha last sync that will work for releng_1. We disabled this as we from now on only want people to use firmwareupdates that we officially release.
                          1 Reply Last reply
                          Reply Quote 0
                          • R
                            rcasas
                            I was having the same problem with RC1, I did the cvs_sync.sh update and my system has updated to RC2, but I was still having the problem.
                            I've looked the code to start a service, and I've seen that the problem was with the function mwexec_bg which is in the /etc/inc/util.inc file
                            When this function calls php exec function, it uses:
                            exec("nohup $command > /dev/null 2>&1 &");
                            I've been trying some combinations, and the problem was with the redirection to stdout, all the others things runs with any problem. So, I've changed the code to look like:
                            exec("nohup $command 2> /dev/null &");
                            And squid then starts through the gui with no problem. I hope this change won't break any other thing (I think the only problem which can cause is about the creation of the nohup.out file)
                            1 Reply Last reply
                            Reply Quote 0
                            • D
                              dvserg
                              Thx
                              I will do testing this too
                              1 Reply Last reply
                              Reply Quote 0
                              • S
                                sullrich
                                This is not the correct fix.  That function is used throughout the system and isnt something we should just start changing for the sake of it.  The problem resides in the package, not in pfSense common functions.
                                1 Reply Last reply
                                Reply Quote 0
                                • D
                                  dvserg
                                  Any body who profy pls look /usr/local/etc/rc.d/squid.sh
                                  In my system this have right 0755 and  group and owner '500'
                                  any other scripts files have owner 'root'
                                  #!/bin/sh
                                  # This file was automatically generated
                                  # by the pfSense service handler.
                                  rc_start() {
                                  	squid -D
                                  rc_stop() {
                                  	squid -k shutdown
                                  # Just to be sure...
                                  killall squid 2>/dev/null
                                  sleep 1
                                  case $1 in
                                  	start)
                                  		rc_start
                                  	stop)
                                  		rc_stop
                                  	restart)
                                  		rc_stop
                                  		rc_start
                                  esac
                                  1 Reply Last reply
                                  Reply Quote 0
                                  • C
                                    Carlo
                                    I'm now running RC2 and I still have the same problem, I'm still not able to run squid from GUI and it also fails to start when i (re)boot.
                                    If the problem above isn't the proper way to fix it what is?
                                    thx,
                                    Carlo
                                    1 Reply Last reply
                                    Reply Quote 0
                                    • S
                                      sullrich
                                      Uninstall and reinstall the squid package.
                                      1 Reply Last reply
                                      Reply Quote 0
                                      • C
                                        Carlo
                                        Seems to be working now :)
                                        Thx!
                                        Carlo
                                        1 Reply Last reply
                                        Reply Quote 0
                                        • H
                                          Hunter
                                          I'm having the same problem with squid to signal 6 exit won't start in the GUI and I'm running RC2, I also can add IP's to the blacklist and nada, zip no blocks on the websites that the IP's refer too. Also I was under the impression that you could enter host names into squid does the slimed down package (squid) for pfsense not allow that (i get error messg) when I put hotmail.com in the blacklist section.
                                          pfSense is a Great system!!!
                                          been there done that two or three times…
                                          1 Reply Last reply
                                          Reply Quote 0
                                          • S
                                            sullrich
                                            1 Reply Last reply
                                            Reply Quote 0
                                            Register Login
