    Upgrade Pfsense system 23 july For Multi WAN + MULTI LAN (Open vpn, Wireless)
    45 Posts 13 Posters 25.5k Views
      gladizxx
      Don't worry be happy with Pfsense…...  :)
        gladizxx
        " If there PFsense". Why must use the other?
          Darkk
          The whole point of open source are options.  PfSense is one option.  IPCop is another option and etc.
          Being the way we are we tend to stick to the ones we like.  As you may have noticed I've used IPCop for years and last year switched to PfSense as it is a more "mature" product for me to use.  IPCop still works but I outgrew it when I started to learn more about enterprise routers.
          PfSense fits in that category.
            gladizxx
            " Make efficient with use "Pfsense" "  :)
              gladizxx
              If you have an internet problem, the solution is in the PFSENSE  :)
                gladizxx
                Solutions to your network problems,  have in Pfsense.  ;D
                • X Offline
                  xbipin
                  gladizxx ,  is it that your are simply trying to increase your post counts on the forum or something like that coz everone of us here really loves pfsense but that doesnt mean u say the same thing a hundred times, rather waste your energy on testing and helping others and bug fixing.
                    jits
                    I have an idea…you can post these comments in the Smoothwall and Vyatta forums.
                    MWHa ha ha ha ha ha ha ahhhhh, ok where's the evil laugh icon, huh? huh?
                      gladizxx
                      "" gladizxx ,  is it that your are simply trying to increase your post counts on the forum or something like that coz everone of us here really loves pfsense but that doesnt mean u say the same thing a hundred times, rather waste your energy on testing and helping others and bug fixing.""
                      In This Post …..
                      ""  I'm just trying to let you know that do not be afraid to do the latest update on the pfsense although there is now a pfsense has been used to doing business on the company or other organization. It is not always in sync is always update to the settings that have been done in the previous pfsense. However, if you find a problem, of course, that will add to the experience and knowledge.""""
                        gladizxx
                        There is a difference in the update 20090527-1245….. ;D  :)  ;D
                          gladizxx
                          Do not worry about Dasboard load balance.
                          on the update 20090530-2140 Dasboard  is running normally.  ;D
                            gladizxx
                            At first I pfsense system upgrade from pfsense system FreeBSD 7.1 to 7.2, in general, do not have constraints, but if there be a little sharper constraints on the traffic, namely the delay in the connection game. Whereas in the other network that uses the 7.1 setting pfsense traffic sharper the same did not experience any problems, aka running very excellent. But after I update with the latest updater (last pfsense system 7.2), everything went normal, although with the same settings before. effisient performance even more than before. so conclusion, I think, please  upgrade your Pfsense system from 7.1 to  Pfsense system FreeBSD 7.2.
                            Don't Worry Be Happy…... :)
                              gladizxx
                              Update-1.2.3-20090612-0600.tgz I then proceed to the last updater pfSense-Full-Update-1.2.3-20090613-0129.tgz, I have a problem on the connection. There is problem in LoadBalance, causing the dissolution internet connection. Although I have been setting up pfsense GUI back problem but is also still running.  :o
                                DeCex
                                @gladizxx:
                                These one kills internet on me after 1-2h of uptime. They can be call badSense, so im backflash to RC1 for now, everything works.
                                pfSense-Full-Update-1.2.3-20090613-0944.tgz
                                pfSense-Full-Update-1.2.3-20090614-0015.tgz
                                • jimpJ Offline
                                  @DeCex:
                                  @gladizxx:
                                  This was likely due to a bug that wasn't allowing the state table to clear out normally. Should be fixed in the most current snapshots.
                                  Do not Chat/PM for help!
                                  • I Offline
                                    idelta
                                    You are right. Version 20090614-0015. Tried every (and many more) :
                                    net.inet.tcp.hostcache.expire=1
                                    net.inet.tcp.keepidle=30000
                                    net.inet.tcp.keepintvl=5000
                                    net.inet.tcp.finwait2_timeout=15000
                                    net.inet.tcp.fast_finwait2_recycle=1
                                    kern.ipc.somaxconn=32768
                                    net.inet.icmp.icmplim=3000
                                    kern.ipc.maxsockets=300000
                                    net.inet.tcp.delayed_ack=1
                                    net.inet.tcp.maxtcptw=196607
                                    Nothing solves the problem : State table growing inevitably !
                                    I would not like to kill more or less running system.
                                    How do we know that the problem is solved ?
                                    "State Timeout in seconds" in Advanced options for firewall rules also does no effect !
                                    • jimpJ Offline
                                      @idelta:
                                      It was fixed today, the most current updates have been confirmed to work by several people.
                                      Try this snapshot, or later:
                                      http://snapshots.pfsense.org/FreeBSD_RELENG_7_2/pfSense_RELENG_1_2/updates/pfSense-Full-Update-1.2.3-20090614-1815.tgz
                                        DeCex
                                        Yey, been up over 2h now, i guess is fixed, thanks
                                          gladizxx
                                          After I upgraded to version 1.2.3-20090614-0015, all with normal pfsense running back, then I upgrade to the latest version 20090616–0034 Pfsense running very wonderfull, internet connection the more aggressive, Load Balance running optimally, as if the entire resource that have empowered perfectly. While the IP Sec're setting me back, because of internal reasons. From there I use my old Pfsense, once I find new problems, while the rest are internal constraints on me.   :)
                                            gladizxx
                                            It seems PFsense, near the start …. stable release ....    :D
