    Upgrade Pfsense system 23 july For Multi WAN + MULTI LAN (Open vpn, Wireless)
    45 Posts 13 Posters 26.3k Views
      Sylhouette
      I use RC2
      1.2.3-RC2
      built on Wed Jun 24 00:36:43 EDT 2009
      It runs on a soekriss 5501, but after a couple of days it stalls, no traffic is coming through any more.
      I can still ping the box but it hangs.
      only a power cycle gets it going again.
      It is my main router so i can not investigate the state and need to reboot as quickly as possible.
      Is has 3 interfaces enabled.
      vr0 LAN
      vr1 WAN pptp
      vr2 DMZ
      Further more nothing special.
      No traffic shaping load balance or other stuff.
      I use revert back to 1.2  now to make sure i get no calls in the evening about a dead router.
      No complains, just an observation!
      regards,
      Johan
        gladizxx
        I have several multi wan router, which I apply on some SOHO multiclient. I always update the pfsense 1.2.3. RC2 latest updater, ( http://snapshots.pfsense.org/FreeBSD_RELENG_7_2/pfSense_RELENG_1_2/updates/ ). In fact I have never experienced problems with the router, all interface with the normal running. The only true version of the updater prior to the current still found the log loadbalance (as in the sticky ( http://forum.pfsense.org/index.php/topic, 16671.0.html ) and I really understand it, because it does not disrupt the performance of the router in general. And up to now all of my router is running normally, without any obstacles that means.
        Not trying to defend.  :)
        just the story of the fact that I experienced.  ;D
        THKS
          Sylhouette
          i think i have been bitten by the following:
          http://cvstrac.pfsense.com/tktview?tn=1935
          regards,
          Johan
            pfsense_fan009
            @gladizxx:
            It seems PFsense, near the start …. stable release ....    :D
            changes from 16juni?
            which version is the latest working? (the latest gives me a huge problem,can't do anything anymore)
            Pfsense 2.x on Alix 2d13 (dual wan with failover).
              gladizxx
              One Pfsense  used for the Multi-WAN, Multi-LAN (wireless, openvpn) can run Load Balance with Normal. Just log on the load balance constraints are still there ….. :)
