    Intermittent connection issue
    115 Posts 6 Posters 32.1k Views 6 Watching
      kevindd992002 @Raffi_
      8.8.8.8 not being answered and not really a huge deal with unbound is something that I agree with, ok, but that was just one sample server. As you can see with the packet capture, almost all servers that I was trying to ping had packet loss one way or another. So with unbound (non forwarding), I'm sure the query to the root hints servers is affected too as it seems that all destination servers are affected when the issue is happening.
      As for the title, yes I'm sorry about that. I should've created a new thread that is not specific to unbound but it just got derailed and hard to abandon now. But if possible, the mods can put it in the correct forum section and let me edit the title.
      @Raffi_ , yes I'll check the suggestions in that link tomorrow :) It's already 1:30AM here and will have to continue tomorrow.
      And yes, I didn't forget about removing pfsense from the mix and try either just the asus router or directly connecting to the modem. Those steps will come eventually.
        And show the tech that pings were sent and not answer - this has ZERO to do with what sent them... If the tech will not believe that.. Then they are an idiot..
        Still not seeing what the problem is.. Like I said its all over the board.. If X is not answering a dns query.. Where is that listed? Was the dns query sent, then again not anything to do with pfsense..
        What else is there to talk about... Simple sniff, if shows traffic being sent, and nothing answered it has nothing to do with pfsense.. There is nothing left to do if you sniff and see traffic being put on the wire, and nothing coming back - its outside the control of what put it on the wire.
        You would have another thing if nothing being sent on the wire, or you see an answer but not being processed.
          kevindd992002 @johnpoz
          @johnpoz said in Non-forwarding Resolver intermittent operation:
          Again, I'm simply asking help in what to tell the tech in trying to rule out pfsense. They are idiots, I agree, but I don't have a choice but to deal with them and convince them that the issue on their side.
          Raffi_R 1 Reply Last reply Reply Quote 0
          • Raffi_R Offline
            Raffi_ @kevindd992002
            @kevindd992002 I'm interested to know how the non pfSense experiments go.
            If push comes to shove and they don't want to help you fix your problem, you nicely explain to them that you'll switch to their competitor (assuming there is one). You'll be surprised at how they suddenly become more interested in helping you solve it.
              You have already proven the issue is there end, when you show a ping going out and not getting an answer.. Not sure what else you can do.. Do the same thing when just a PC connected to their device..
                @Raffi_ said in Non-forwarding Resolver intermittent operation:
                Yeah, me too. I'll try accomplishing both direct-to-modem and using the Asus router tests this week and will report back. Thanks.
                Yeah, I know how ISP's react when you say that. They panic and makes things solved faster. There are competitors, for sure, but in my condo there's only one offering FTTH connections, the one that I'm using now. The others are using crappy phone copper cables which are very substandard. And I just switched from that copper ISP to this fiber ISP since January 2019 so not long ago.
                  Where your going to have a problem is pinging stuff off their network and getting packet loss - they can always just say not their network..
                  You need to have pings going to their network, and not getting back answers.. Also many (all really) an ISP do not promise zero loss, so unless you have significant packet loss - good luck.. TCP can work just fine with a small amount of packet loss.. Do they have anything in their SLA about amount of packet loss?
                  If you call and say yeah over 10k pings I saw .01% loss - they will just laugh and say, ok so? But if you show that you have sustained loss say 5% then you might have something to complain about.
                  So I am going to say it again, a few packets here or there loss is not going to be an issue.. And not the root of your problem with issues with resolving stuff.. Is not like dns only does 1 query, and if no answer just says F it, doesn't work... DNS will send multiple queries before it gives up, and can even switch to tcp vs udp, etc. So for packet loss to be a problem with dns resolution it really needs to be a significant issue.
                  Also - for resolving, not forwarding the different NS will be tried - for example roots have 13 different NS, if one does not respond another will be tried.. Unbound keeps track of which ns respond faster, etc. And will use them more then ones that are less responsive.. Look at your infra cache..
                  If your having dns resolving issues - you need to troubleshoot that specific issue.. Not just that you lost some pings to 8.8.8.8
                    I'm going to ask this again too: Would a 10-minute ping to google.com with ALL RTO's not considered an issue for you? I'm really having a hard time thinking why you wouldn't consider that an issue.
                    Like I said, I CARE LESS for few RTO's because they will be retried anyway, I agree with you completely. But if you start getting 100% RTO for a span of even just one minute and your clients cannot browse the Internet 100%, then where in the world is that not an issue?
                      kevindd992002
                      I will record a video of the issue when I get the chance and post it here as proof.
                        10 minutes yeah that is a problem - But maybe outside the isp control, maybe its somewhere past where the traffic leaves the ISP.. You can get them to troubleshoot it is happening all the time and you can not get to google. But 8.8.8.8 is not google.
                        And 8.8.8.8 does not have anything to do with overall dns, unless its the authoritative NS for what your looking for and can not talk to.. Which seems really odd, since its an anycast.. Unless you are forwarding to it, which per your title you are not.
                        If you can show an outage pinging 8.8.8.8 for 10 minutes - then for sure you can bring that to your ISP attention and say hey - WTF... But unless you can show them that it happens more than once in a while your going to have a hard time getting their attention.
                        edit: Do not post any stupid videos.. JFC nobody is going to watch such nonsense... You can either resolve something or you can not, you can either ping something you can not... Show the sniff of the traffic, show the traceroute to the IP.. So the sniffs of the resolving action and getting no response, etc.
                        BTW - here are the NS involved in resolving google.com.. Notice 8.8.8.8 not there
                        [2.4.4-RELEASE][admin@sg4860.local.lan]/: unbound-control -c /var/unbound/unbound.conf lookup google.com
                        The following name servers are used for lookup of google.com.
                        ;rrset 78708 4 0 2 0
                        google.com.     78708   IN      NS      ns2.google.com.
                        google.com.     78708   IN      NS      ns1.google.com.
                        google.com.     78708   IN      NS      ns3.google.com.
                        google.com.     78708   IN      NS      ns4.google.com.
                        ;rrset 78623 1 0 1 0
                        ns4.google.com. 78623   IN      A       216.239.38.10
                        ns4.google.com. 78623   IN      AAAA    2001:4860:4802:38::a
                        ns3.google.com. 78623   IN      A       216.239.36.10
                        ns3.google.com. 78623   IN      AAAA    2001:4860:4802:36::a
                        ns1.google.com. 78623   IN      A       216.239.32.10
                        ns1.google.com. 78623   IN      AAAA    2001:4860:4802:32::a
                        ns2.google.com. 78623   IN      A       216.239.34.10
                        ns2.google.com. 78623   IN      AAAA    2001:4860:4802:34::a
                        Delegation with 4 names, of which 0 can be examined to query further addresses.
                        It provides 8 IP addresses.
                        2001:4860:4802:34::a    expired, rto 154191216 msec, tA 0 tAAAA 0 tother 0.
                        216.239.34.10           rto 223 msec, ttl 776, ping 7 var 54 rtt 223, tA 0, tAAAA 0, tother 0, EDNS 0 probed.
                        2001:4860:4802:32::a    rto 376 msec, ttl 776, ping 0 var 94 rtt 376, tA 0, tAAAA 0, tother 0, EDNS 0 assumed.
                        216.239.32.10           not in infra cache.
                        2001:4860:4802:36::a    rto 376 msec, ttl 776, ping 0 var 94 rtt 376, tA 0, tAAAA 0, tother 0, EDNS 0 assumed.
                        216.239.36.10           rto 311 msec, ttl 776, ping 3 var 77 rtt 311, tA 0, tAAAA 0, tother 0, EDNS 0 probed.
                        2001:4860:4802:38::a    rto 376 msec, ttl 776, ping 0 var 94 rtt 376, tA 0, tAAAA 0, tother 0, EDNS 0 assumed.
                        216.239.38.10           rto 252 msec, ttl 776, ping 4 var 62 rtt 252, tA 0, tAAAA 0, tother 0, EDNS 0 probed.
                          I know 8.8.8.8 is not google.com. These are two different servers that I showed in my tests above. I'm not sure why you're not following.
                          Well, I thought a video will help you believe me that there's a problem. If you don't want it, then fine. Obviously, your network troubleshooting skills are way better than mine but I make it to the point to give any information I deem necessary for everyone to check. This is why I'm asking for guidance.
                          I thought we're already past the point where we're not considering this to be a DNS issue anymore? If it was, then the resolution part is where I'll have issues but when the issue happens pinging random servers show RTO's as well. I'm not mentioning here that it is a DNS issue. 8.8.8.8 was just the monitor IP I have for the WAN gateway from the very start so that's what I showed everyone in this forum.
                            kevindd992002
                            Here's a traceroute that I sent them a few months ago: https://pastebin.com/JqPx326v
                            That looks like the RTO starts from the hop that's within the ISP network. Is that enough evidence for them to conclude that the problem is in their network?
                            And then 3 minutes after the issue, it got resolved and the traceroute results became like this: https://pastebin.com/XYbNMiWy
                              You got to the end point in that trace.. That all hops along the way do not naswer does not always mean anything..
                              Not sure what you think that shows as a problem?
                              Tracing route to www.pfsense.org [208.123.73.69]
                              over a maximum of 30 hops:
                                1    <1 ms    <1 ms    <1 ms  192.168.9.253
                                2    10 ms     9 ms    16 ms  50.4.132.1
                                3    11 ms    17 ms    10 ms  76.73.191.106
                                4     9 ms     9 ms     8 ms  76.73.164.142
                                5    12 ms    10 ms     9 ms  76.73.164.154
                                6    13 ms    10 ms    10 ms  76.73.191.242
                                7    11 ms    21 ms    10 ms  143.59.95.224
                                8    30 ms    15 ms    18 ms  75.76.35.8
                                9     *       13 ms    11 ms  4.16.38.157
                               10     *        *        *     Request timed out.
                               11    36 ms    46 ms    37 ms  4.14.49.2
                               12    41 ms    35 ms    35 ms  64.20.229.158
                               13    36 ms    35 ms    35 ms  66.219.34.194
                               14    34 ms    38 ms    35 ms  208.123.73.4
                               15    39 ms    35 ms    39 ms  208.123.73.69
                              So from that trace I guess I am having issues getting to www.pfsense.org?
                              same goes for cnn seems
                              $ tracert -d www.cnn.com
                              Tracing route to turner-tls.map.fastly.net [151.101.185.67]
                                1    <1 ms     3 ms    <1 ms  192.168.9.253
                                2    10 ms    11 ms    16 ms  50.4.132.1
                                3    19 ms    20 ms     8 ms  76.73.191.106
                                4    11 ms    10 ms     9 ms  76.73.164.142
                                5    13 ms    10 ms    11 ms  76.73.164.154
                                6    10 ms    11 ms    11 ms  76.73.191.242
                                7    10 ms    10 ms    10 ms  143.59.95.224
                                8    13 ms     9 ms    10 ms  75.76.35.8
                                9     *        *        *     Request timed out.
                               10    12 ms    10 ms    10 ms  151.101.185.67
                                Of course not! Some routers are setup to not respond to ICMP requests, I know that.
                                But how do you explain my first and second traceroute before and after (three minutes interval) the issue? Is it because the route to the same server changed in a span of 3 minutes?
                                • Raffi_R Offline
                                  @kevindd992002 said in Non-forwarding Resolver intermittent operation:
                                  @kevindd992002 That's not really proof of an issue on their network. Not all hops along the route will always respond. It's common to have hops that don't respond along the route. As long as at the end you get to the server, that's what matters. Also, the hops are not taking very long so that also looks OK.
                                    Right, that's what I thought. I just posted the screenshots here in case you guys see something out of the ordinary.
                                    • Raffi_R Offline
                                      Off topic, but we're actually in the copper test industry. Believe it or not, they have technology now that is able to get close to Gigabit speeds on those old copper lines if the ISP is willing to invest in it. I'm curious are you in Australia? Here in the US, the old phone lines have been mostly abandoned in terms of further investment.
                                        I can imagine. I was mostly talking about how sub-standard the copper wires are here in our condo. Even the copper ISP's themselves tell me that the copper wires that the contractors used in this condo are crap. The copper wires in the building's cabinet are worse than how spaghetti looks like. And no one wants to invest to replace those. I'm in the Philippines, so a third-world country, but Internet service here came a long way already. My two service plans are 35 down/35 up (around $31) and 300 down/300 up (around $87).
                                          kevindd992002
                                          @Raffi_
                                          The Asus router as the main router and without pfsense has been issue-free for the last two days. It's still too early to tell but I'll continue monitoring during the weekend (the time when the issue usually occurs most) before I come to a conclusion. If it does run flawless until Monday though, I'm not sure how to continue troubleshooting pfsense except to uninstall and reinstall it from scratch. I mean that's an easy task when I just need to reload the config but if I am to go that route I would want to not carry over any settings from the config (which might be corrupted or something, for all we know).
                                          • Raffi_R Offline
                                            Raffi_
                                            @kevindd992002 Interesting. Ok, that sounds like a good plan. Yea give it a little while to see how it goes. We'll see what the next step is from there. Have a good weekend.
                                            Raffi
