    IPSEC + VTI + IKEV2 - will not auto-reconnect
    26 Posts 8 Posters 5.9k Views 9 Watching
    • jimpJ Offline
      jimp Rebel Alliance Developer Netgate @ay
      That is best. Set one side to connect + keep alive, set the other side to responder only.
      Do not Chat/PM for help!
        mdomnis @jimp
        @jimp I just enabled that option now and in my first two tests of > 5 minute outage, it seemed to do the job. Not sure why I didn't see that there. Doesn't help for 2.5.2, but I'll have to be patient I guess. :)
        Are you able to comment on the use of gateway monitoring on the VTI gateways? It was enabled by default just pointing to the remote side IP in the /30, but the results I had when testing with 2.5.2 were not good in that if I had a HQ site with 10 VTI tunnels to branch sites, any time ONE of the branches suffered an outage, there would be brief outages to all branches when the gateway goes down and again when it comes back up. I believe this was due to IPSEC restarting. TAC suggested disabling the gateway monitoring and it has helped get me much more stable. Wondering if it makes sense to update the docs with this advice or perhaps even default it to disabled for VTI gateways? Or if there is another fix in the works that might only restart the tunnel having an issue and not all of them.
        Thanks.
        • jimpJ Offline
          Gateway monitoring seems to work fine for me but YMMV. If it gives you trouble, turn it off. For most uses of VTI it isn't all that necessary, though it is nice to know if the VPN is experiencing packet loss.
          Some uses of VTI such as for failover with policy routing would need to keep monitoring enabled. Some people fail from VTI to an interface, or an interface to VTI, or VTI to VTI.
          The defaults are just the defaults and can easily be changed by users who need or prefer different behavior.
            shellbr
            I just upgraded one side of a tunnel (the side that always initiates) to 2.6.0. It was a great time to test since I needed to take the other (responder only) site down for a 2 hour window anyway. When I brought the network back up, the IPSec tunnel was reconnected by the opposite side, so that's a success! I still have the responder only side on 2.52 and will upgrade it soon. Anyway, great work and I'm so glad the new feature provided in 2.6 resolved this long-standing issue. Thanks to all the developers!
              bbrendon @jimp
              Hi @jimp .
              Regarding the "Keep Alive - Enable periodic keep alive check" option, should that be enabled on both sides or just the side initiating the connection?
              • jimpJ Offline
                jimp Rebel Alliance Developer Netgate @bbrendon
                @bbrendon said in IPSEC + VTI + IKEV2 - will not auto-reconnect:
                Hi @jimp .
                Usually just the side initiating
