    Help me with squid guard
    25 Posts 3 Posters 8.3k Views
    • I Offline
      iamthed
      @dvserg:
      Also if you setup browser proxy options  - what behavior with blocking ?
      i wanna test the squidguard is working.. so i deny all as the default..
      if my default is deny then it must be block anything right..
      but i still can browse..
      or i should reinstall sg and squid and installed it again?
      hey if you don't mind can u PM me ur printscreen squid+squidguard
      i'd like to see it..
      i'm affraid that i misconfigure about the squid..
      and sorry if it's bother you..
      i'm dumb.. but i have a desire to learn
        dvserg
        Try this pls
        • disable transparent mode in squid, disable squidGuard
        • set you brouser Proxy options as squid configured (ip/port)
        • test http browsing = must work
        • enable SG, remove all ACL's, Default page set [all Deny], disable safesearch, Apply
        • test HTTP browsing - must be nothing.
        SquidGuardDoc EN  RU Tutorial
        Localization ru_PFSense
        • I Offline
          iamthed
          @dvserg:
          Try this pls
          thx for ur answer but when i configure like u said i have a problem..
          when i set proxy..
          it cannot connect to internet..
          plz see the picture below
          any idea where it might be wrong??
          thx again
          1.JPG_thumb
          2.JPG_thumb
          3.JPG_thumb
          4.JPG_thumb
            dvserg
            Why enabled squid upstream proxy? Squid has parent proxy server ?
            And you browser must be set to squid IP/Port, but not to upstream proxy setting.
            • I Offline
              iamthed
              @dvserg:
              thx.. it's worked.. it's blocked everything.. even i tried to change the default rules to allow all traffic..  ???
              but how to enable the transparent proxy server..
              so if client want to access website with port 80 they go to proxy server..
              cmiiw if i'm using transparent proxy it means i don't need to setup the browser proxy right?
              i already setup the like this but it's blocked all traffic..
              thx dvserg
              gbr2.JPG_thumb
              gbr3.JPG_thumb
              gbr1.JPG_thumb
