    Not able to run speed tests while using Squid Proxy
    2 Posts 2 Posters 2.5k Views 2 Watching
      solaris81
      Hello,
      I have a basic squid proxy setup going. I do not have any issues with the exception of not being able to run speed tests from every speed test site I have tried.
      Some I have tried are:
      speakeasy.net
      speedtest.net
      speedtest.xfinity.com/
      I usually get an error saying unable to connect or that something went wrong. If I disable the proxy, I have no issues.
      I have disabled all blacklists and ACLs.
      Squid Access Table shows:
      30.12.2019 16:09:07 10.0.0.51 TCP_DENIED/403 slc-speedtest.integra.net:5060 - -
      30.12.2019 16:09:07 10.0.0.51 TCP_DENIED/403 saltlakecity2.speedtest.centurylink.net:5060 - -
      30.12.2019 16:09:07 10.0.0.51 TCP_DENIED/403 speedtest.sumofiber.com.prod.hosts.ooklaserver.net:5060 - -
      30.12.2019 16:09:07 10.0.0.51 TCP_DENIED/403 speedtest.vivintwireless.com.prod.hosts.ooklaserver.net:5060 - -
      30.12.2019 16:09:07 10.0.0.51 TCP_DENIED/403 speedtest.uen.net.prod.hosts.ooklaserver.net:5060 - -
      30.12.2019 16:09:06 10.0.0.51 TCP_DENIED/403 speedtest.firstdigital.com.prod.hosts.ooklaserver.net:5060 - -
      30.12.2019 16:09:06 10.0.0.51 TCP_DENIED/403 speedtestc.xmission.com.prod.hosts.ooklaserver.net:5060 - -
      30.12.2019 16:09:04 10.0.0.51 TCP_DENIED/403 saltlakecity2.speedtest.centurylink.net:8080 - -
      30.12.2019 16:09:04 10.0.0.51 TCP_DENIED/403 slc-speedtest.integra.net:8080 - -
      30.12.2019 16:09:04 10.0.0.51 TCP_DENIED/403 speedtest.vivintwireless.com.prod.hosts.ooklaserver.net:8080 - -
      30.12.2019 16:09:04 10.0.0.51 TCP_DENIED/403 speedtest.sumofiber.com.prod.hosts.ooklaserver.net:8080 - -
      30.12.2019 16:09:04 10.0.0.51 TCP_DENIED/403 speedtest.uen.net.prod.hosts.ooklaserver.net:8080 - -
      30.12.2019 16:09:04 10.0.0.51 TCP_DENIED/403 ogd-speedtest.zx4.com:506 - -
      30.12.2019 16:09:04 10.0.0.51 TCP_DENIED/403 ogd1-speedtest.gorillaservers.com.prod.hosts.ooklaserver.net:5060 - -
      30.12.2019 16:09:04 10.0.0.51 TCP_DENIED/403 stosat-utah-01.sys.comcast.net.prod.hosts.ooklaserver.net:5060 - -
      30.12.2019 16:09:03 10.0.0.51 TCP_DENIED/403 speedtest.firstdigital.com.prod.hosts.ooklaserver.net:8080 - -
      30.12.2019 16:09:03 10.0.0.51 TCP_DENIED/403 speedtestc.xmission.com.prod.hosts.ooklaserver.net:8080 - -
      30.12.2019 16:09:03 10.0.0.51 TCP_DENIED/403 saltlakecity2.speedtest.centurylink.net:5060 - -
      30.12.2019 16:09:02 10.0.0.51 TCP_DENIED/403 slc-speedtest.integra.net:5060 - -
      30.12.2019 16:09:01 10.0.0.51 TCP_DENIED/403 ogd-speedtest.zx4.com:808 - -
      30.12.2019 16:09:01 10.0.0.51 TCP_DENIED/403 ogd1-speedtest.gorillaservers.com.prod.hosts.
        Gertjan
        Proxies need end user programs - like browsers, mail programs, etc to be aware of them.
        "speedtest-cli" is a simple tool, at least the one you can install on pfSense, isn't aware of proxies so it can't get out.
        I advise you to carefully select two meaningful words like speedtest-cli proxy, feed them into your favourite web search engine, and then do what has been said here.
