    changing vga mode to serial console mode
    25 Posts 7 Posters 3.4k Views 7 Watching
      alirz @JKnott
      @jknott well in my case, I have serial image version of pfsense installed. I notice that on the vga output, the display stops updating at some point of the boot process, however I get the full output in the serial console till the boot is finished. Is that normal? That's why I was wondering if I could flip between serial vs vga as primary output modes?
        alirz @stephenw10
        @stephenw10 said in changing vga mode to serial console mode:
        Yes, like I said on the serial only image there is no option to disable the serial console by default. Otherwise you could easily lock yourself out. 😉
        Try removing the file: /cf/conf/enableserial_force.
        That should allow you see the console options.
        Cool thanks will check that out. Is it also possible to force vga as primary mode via a similar method for a serial.inage?
          That is normal if serial is set as the primary console.
          No there is no force file for vga.
          • JKnottJ Offline
            JKnott @alirz
            @alirz said in changing vga mode to serial console mode:
            Is that normal?
            I've never seen that.
            You mentioned it locks up in VGA. That might be a hardware issue.
            UniFi AC-Lite access point
            • JonathanLeeJ Offline
              JonathanLee @JKnott
              @jknott The earliest computer I had was an At&t PC6300 it had a DB-9 for the keyboard, monochrome guy. I also remember my Tandy 102 my uncle got us one christmas had a DB25 on the back. My Dad had a Commodore 64 I never got to play with it. The thing was disconnected by the time I was able to. Again, the monitor was dead that went with it and it was outdated at that point but that guy had some connections on the back also. Today I have the C64 mini so I got to play with it in the end, Thank you Santa!!!
              Make sure to upvote
