    WAN connection randomly drops?
    41 Posts 6 Posters 10.7k Views 5 Watching
      If you disable the gateway monitoring action it will not actually do anything other then set an alarm.
      Check the quality monitoring graphs in Status > Monitoring. Are you seeing packet loss consistently or just spikes before it goes down?
      How were you monitoring the connection be fore you had pfSense?
      • E Offline
        ExecutableFix @stephenw10
        @stephenw10 This is the graph showing the packet loss at the moment it goes downf9a952f7aff57918b2f50fd3935cd9ab.png
        There are no other spikes (traffic, packets etc) to be found. It's just plain packet loss at a random time. I wasn't really monitoring the connection before pfSense, but I never experienced internet outages this often. The only outages that happened were more like 1 hour+ long and those only happened rarely
        • JKnottJ Offline
          JKnott @ExecutableFix
          @ExecutableFix said in WAN connection randomly drops?:
          That shouldn't be the reason for a random drop.
          Poor connections are often the cause of intermittent failure. I've seen those RJ45s fail many times.
          UniFi AC-Lite access point
          • E Offline
            ExecutableFix @JKnott
            @JKnott
            @JKnott said in WAN connection randomly drops?:
            This is different tho, plus there definitely wouldn't be a pattern
              Ok, good news. The binary part of the fix for this is now in 2.4.5 snapshots:
              https://github.com/pfsense/FreeBSD-src/commits/RELENG_2_4_5/sbin/dhclient/dhclient.c
              The next available snapshot should have it. The full fix also requires changes to the dhclient script which can be applied via the system patches package. I have briefly tested that and it didn't seem to break anything.
              That patch is here: https://redmine.pfsense.org/attachments/download/2682/pfsense-dhclient-script-patch.txt
              If you're able to test it we may be able to include it in 2.4.5.
              E 2 Replies Last reply Reply Quote 1
              • E Offline
                @stephenw10 Oh that's awesome news. I'll try to give it a shot tomorrow. Hopefully this is indeed the fix for the random drops
                • E Offline
                  • E Offline
                    ExecutableFix
                    I've just installed 2.4.5_RC and applied the patch, let's see if this works
                    • E Offline
                      ExecutableFix
                      Update:
                      Feb 26 11:25:15	check_reload_status		Reloading filter
                      Feb 26 11:25:15	check_reload_status		Restarting OpenVPN tunnels/interfaces
                      Feb 26 11:25:15	check_reload_status		Restarting ipsec tunnels
                      Feb 26 11:25:15	check_reload_status		updating dyndns WAN_DHCP
                      Feb 26 11:25:15	rc.gateway_alarm	44749	>>> Gateway alarm: WAN_DHCP (Addr:185.47.x.1 Alarm:0 RTT:1.455ms RTTsd:.288ms Loss:5%)
                      Feb 26 11:23:19	check_reload_status		Reloading filter
                      Feb 26 11:23:19	check_reload_status		Restarting OpenVPN tunnels/interfaces
                      Feb 26 11:23:19	check_reload_status		Restarting ipsec tunnels
                      Feb 26 11:23:19	check_reload_status		updating dyndns WAN_DHCP
                      Feb 26 11:23:19	rc.gateway_alarm	87807	>>> Gateway alarm: WAN_DHCP (Addr:185.47.x.1 Alarm:1 RTT:1.437ms RTTsd:.274ms Loss:21%)
                      I don't know what to do anymore. This happened after the patch had been applied. The loss is always about 20% and the interval matches again: 1.5~1.6 days. That can't be a coincidence anymore
                        bcruze
                        Under interface -wan -advanced there is a reject dhcp lease option
                        Put the wan-dhcp ip there and apply to see if it helps
                        This was the last thing I tried before getting a static ip from my provider which ultimately fixed my issue
                        • E Offline
                          ExecutableFix @bcruze
                          @bcruze Could you provide a screenshot? I can see these settings:
                          I also calculated the time between the downtimes and it's 1 days, 7 hours and about 40~50 minutes every time. It's definitely some sort of lease time issue
                            bcruze
                            i worded it wrong apologies.
                            reject leases from : is the area i ment to say.
                            you can also try the FreeBSD default for a preset. i tried it but it did not fix my issue
                            its kind of confusing, if you tweak it you have to select saved cfg to see what its actually set too. at first i didn't think it was saving my settings...
                            • E Offline
                              @bcruze So setting that option to the x.x.x.1 ip should reject new leases and thus not disconnect my internet. Was your issue exactly the same? Is it something that is caused by the way pfSense handles these things?
                                bcruze
                                according to what i've read Pfsense should ignore the lease change. at least what i've read online.
                                i changed ISP from charter spectrum to a carrier grade nat fiber to the home company. previously my IP never changed with spectrum so i never saw this issue. with CGNAT my Nokia modems internal ip changed roughly every 24-29 hours. my internet would go down and unplugging the cable from the nokia from pfsense and plugging it back it would fix it. OR if you went into status - interface > release wait a few seconds then renew. my connection would come back up.
                                my work around is paying 10 dollars a month(static IP address) to my provider to stay online as they have no way of changing the programming of the Nokia modem. all the other modems they did not suggest. and i refuse to replace my Pfsense routers, ubnt POE switches and ubiquiti Nano, LR access points! to their equipment...
                                • E Offline
                                  @bcruze I unfortunately don't have the option to get a static IP, but my IP has infact never changed before so I'm not too worried about that happening. The only thing I'm concerned about is the fact that the internet automatically comes back up again (which could indicate an issue with my isp rather then pfSense). I've not had to manually do anything for it to be online again. I'll definitely give this a shot and see of it resolves anything.
                                  • F Offline
                                    flyboy320
                                    I know you are trying to troubleshoot and find the actual issue, but as a last resort I would still give 2.5 a try.
                                    • E Offline
                                      ExecutableFix @flyboy320
                                      @flyboy320 I'll give @bcruze's method a try first, if that doesn't work then I might upgrade to 2.5. I still think it's an ISP issue
                                        Check the DHCP log though at that time. Look for dhclient trying and failing.
                                        I just realised I got confused between threads. I meant to have @bcruze test this because what he's seeing does look like dhcp. 🙄
                                        • E Offline
                                          @stephenw10 Interesting thing is, the dhcp logs don't indicate any issue
                                          • JKnottJ Offline
                                            @ExecutableFix
                                            The DHCP logs won't show anything, unless it fails to get an address. That will only happen when it tries to renew the address. This is typically around 1/2 or 2/3 the lease time. If the connection fails before then, it won't show in the log. When I had a connection problem, several years ago, I wrote a script to ping my ISP's gateway every minute and logged when it failed. This gave me a list of when it failed and restored.
