    Intermittent Problems Reaching Anything Beyond pfSense Firewall
    33 Posts 5 Posters 4.6k Views
    • TangoOverswayT
      TangoOversway @Raffi_
      @Raffi_ said in Intermittent Problems Reaching Anything Beyond pfSense Firewall:
      The monitoring graph as it is currently doesn't tell us a whole lot other than pfSense was able to ping your modem without issues.
      Then is it having delays while I was downloading a lot of data normal, since the interface was in use at that point?
      Going forward though, since the monitoring IP has been changed to something out on the web it should be more useful.
      I'm hoping it gives me something good. I take it that if it shows the gateway as down, or packet losses, or anything like that, that will prove it's the internet router and not something I've done wrong in the firewall?
      • TangoOverswayT
        I'm a little confused by that tiktok gateway. What is that? Is it an interface which provides web access?
        tiktok was the host name of the old firewall. I may have typed that in, out of habit, when I set things up. (I used to have an Oz theme to all the names on my LAN, now it's Tolkien.) pfSense won't let me change it and says something about how it can't allow changing gateway names. It's to the LAN. I use the 172.16.7.xxx address space on my LAN. The 192.168.0.xxx space is the no-man's-land zone between the internet router and my firewall. What I don't get is that the router is 192.168.0.1 and serves as the DHCP for that zone (which is only the LAN side of the internet router and the WAN side of the firewall).
        Just to clarify - Internet comes into the wireless router, then the router's LAN interface at 192.168.0.1, then to the firewall's WAN interface at 192.168.0.180, then on the LAN side of the firewall is 172.16.7.1.
        • Raffi_R
          Raffi_
          I wouldn't worry about that. Those numbers looked fine. If you look at my graph my peak standard deviation was around 4ms even higher than yours. That's not really telling us much. It's definitely not an issue and nothing to worry about.
          We'll have to wait and see, but basically yes. If you can't ping past the modem then you're modem or something upstream is likely the issue.
          It sound to me like tiktok should not be a gateway at all. Don't try to rename it, delete it completely from that list. It sounds like that was something that might have been copied over from the old setup but shouldn't be there.
          TangoOverswayT 2 Replies Last reply Reply Quote 0
          • TangoOverswayT
            @Raffi_
            Quite possible. I don't remember timing, but at some point in the past, I was updating my old pfSense regularly. Then there was some change, I forgot what it was, but instead of just saving the config, then updating it through the web interface, there was more to do. I don't remember what, but I remember part of the issue was that I'd have to make a new image file (and use a serial cable - and mine had busted) and that the config file format had changed or something.
            So when I installed this firewall, I didn't even bother to save the config and load it. Since there was some reason that wouldn't have worked 10 years ago, I didn't even try it now. I just took screenshots of everything and copied it all by hand. I could have just entered 'tiktok' accidentally somewhere without thinking it over.
            • TangoOverswayT
              @Raffi_ :
              Here's what I get when I pick related settings for the interfaces. It indicates tiktok is on the LAN interface. Did I set something up wrong or is it just the gateway from the firewall to the LAN?
              • Raffi_R
                Raffi_
                172.16.7.1 is your LAN interface? If so, then tiktok should be deleted from Gateways.
                TangoOverswayT 1 Reply Last reply Reply Quote 0
                • TangoOverswayT
                  Could that be causing problems with stuff being routed incorrectly or something like that? (I'm deleting it - just wondering if it could be part of the issue.)
                  Raffi_R stephenw10S 2 Replies Last reply Reply Quote 0
                  • TangoOverswayT
                    TangoOversway
                    I'm seeing better results now than before. I've also found out that the Google server I was pinging as my way to check on my internet router is not always returning data even when everything else is okay. (I tried pinging several different sites, by domain and IP address, including a different Google server and I found that even when I could ping everything else, sometimes that server I had been using to test was down.)
                    With @Raffi_'s help, I've been monitoring the connection with a Monitor IP address and when I have problems, I check the graph and see that there has been no packet loss at all during those times. That makes me think it is the firewall after all, and likely DNS issues, so I'm going to start another thread, since that's an entirely different topic.
                    • Raffi_R
                      Raffi_ @TangoOversway
                      It could have been part of your problem. Maybe not the source of your problem, but it was definitely a configuration error which needed to be corrected.
                      If you're suspecting the issue is a firewall configuration problem, then you might be better off setting up pfSense from scratch using the wizard. The settings right out of the box should work fine. Ask yourself, what specific settings did you copy over from the old firewall that are actually important. Then reconfigure them later if needed. Manually copying settings from a 9 year old firewall could have very well been your problem all along.
                      Edit:
                      You could still be having issues with that IPV6 gateway if that's not configured right. Why don't you try removing that as well. It might solve your problem.
                      • TangoOverswayT
                        TangoOversway
                        @Raffi_ : I figured that issue out and am having good internet access now. The problem I'm still running into is getting DNS to work on my LAN with the DHCP. I must have copied something wrong from the original firewall when I changed over. Anyway, it comes down to things working well when I stopped using the DNS Resolver. (That's why I think I must have copied something wrong or set it up wrong when I activated DNS on pfSense.)
                        So I've posted a new thread here that starts with the DNS issues, overall, and mentions that now the DNS just doesn't seem to want to behave.
                        • stephenw10S
                          stephenw10 Netgate Administrator @TangoOversway
                          @TangoOversway said in Intermittent Problems Reaching Anything Beyond pfSense Firewall:
                          In 2.4.X the system default gateway is set to automatic by default, yours is in the screenshot there. If you have more than one IPv4 gateway and the main WAN fails it will failover to any others available. Here you have the LAN interface itself set as a gateway, if the system sets that as default you will end up with no connectivity.
                          You should set the system IPv4 default gateway to WAN_DHCP to avoid that ever happening.
                          The only reason you might have a gateway set as the LAN interface is to route traffic over IPSec. This:
                          https://docs.netgate.com/pfsense/en/latest/vpn/ipsec/accessing-firewall-services-over-ipsec-vpns.html
                          If you were/are not doing that it's probably an invalid gateway.
                          • TangoOverswayT
                            TangoOversway
                            @stephenw10 said in Intermittent Problems Reaching Anything Beyond pfSense Firewall:
                            Could that have resulted in some kind of intermittent non-connectivity? If so, that might explain a lot. But I don't see how I could have created that gateway accidentally!
                            I reset to factory defaults and that fixed that and some other issues. But it helps to know what was going wrong, since it was such a puzzle and so frustrating!
                            I didn't set that up and know I wouldn't have done that at all until I had the basic system working first, so I'm figuring that extra gateway was because I checked a box I didn't mean to or something like that.
                            If it cause the problems, then it would be nice to know the culprit was found.
                            • stephenw10S
                              The most common way people add a LAN gateway by mistake is if they add a new internal interface in the webgui or they set a new IP address on the existing LAN from the console menu. In both those situations you are presented with an option to add a gateway. There is text guidance explaining that only 'WAN' type interfaces should have a gateway but it's easy to think you are entering the gateway clients should use and add the LAN IP as a gateway. That's incorrect but we see a lot of people do that. 😉
                              Only WAN interfaces should have a gateway defined on them directly. That is adding a gateway for the firewall itself not a gateway for clients to use. pfSense uses the presence of a gateway on an interface to identify it as a WAN and will add automatic outbound NAT rules to it.
