    NEED help problem with routing and default gateway
    4 Posts 2 Posters 3.0k Views
      bbozo
      The situation is this:
      wireless
      pc(172.38.11.50)->switch->{lan}(172.38.11.3)Wrap2{Opt1}(10.55.10.4)–-><----(10.55.10.2){Opt1}Wrap1(172.38.10.3){lan}->switch
        {wan}172.38.11.4                                            {wan}172.38.10.4                           ^
        !        (172.38.10.1)
        My Server
        (dhcp ip from ISP)
        INTERNET
      Wrap1
      firewall is all allow on all intefraces
      none of the interfaces are bridged
      on wan interface gateway is set to 172.38.10.1 (i tried Opt1/wrap1 and lan/wrap1)
      static routs are:
      int            net                      gtw
      lan      172.38.11.0/24     172.38.11.3
      opt1   172.38.10.0/24     10.55.10.2
      opt1   10.55.10.0/24       10.55.10.4
      Wrap2
      static routs are:
      int            net                      gtw
      lan      172.38.10.0/24     172.38.10.3
      opt1   172.38.11.0/24     10.55.10.4
      opt1   10.55.10.0/24       10.55.10.2
      I have two networks in diferent subnets (172.38.10.0/24 and 172.38.11.0/24) i am trying to connect both network to internet. The problem i have is this: Network behind wrap2 can't go to internet, but the interesting part is that all ping's are resolved for example if i ping www.pfsense.com it resolves the ip address but i get no reply. I can reach all computers in both networks.
      If I put another static route in wrap2: int       network             gtw***
        opt1     0.0.0.0/1          10.55.10.2
      i get (of course) only parts of the internet. So my conclusion is that the default gateway is not doing its job on wrap2.
      My question is how to set the default gateway on wrap2?
      Any help i MOST APRICIATED.
      PS. i have been trying to solve this for days. Sorry for bad english.
      • L Offline
        lsf
        This is how it should look:
        pc(172.38.11.50)->switch->{lan}(172.38.11.1)Wrap2{WAN}(10.55.10.2)–->WIRELESS<----(10.55.10.1){LAN}Wrap1(172.38.10.2){WAN}->switch
        !        (172.38.10.1)
        My Server
        (dhcp ip from ISP)
        INTERNET
        Wrap1:
        WAN = sis0
        LAN= wireless interface
        static route:
        172.38.11.0/24 GW=10.55.10.2
        Wrap2:
        WAN = wireless interface
        LAN = sis0
        wan interface gateway is set to 10.55.10.1
        That should be it.
        On wrap2 you can also remove the NAT rule if you like.
        But it has to be on on wrap1, if it's not on then you also need to tell your DSL router(or whatever device you have) that it can reach 10.55.10.0/24 and 172.38.11.0/24 on GW 172.38.10.2.
        -lsf
          bbozo
          Thanks for the tip Isf I will try this and tell you if it worked tomorow.
            bbozo
            YES that  was it….problem solved.
            But for the information i didnt change anything on wrap1, i only changed wrap2 settings and that did the job.
            thank you
