    Traffic Totals Hourly Report Problem
    Scheduled Pinned Locked Moved Traffic Monitoring
    46 Posts 10 Posters 16.5k Views 13 Watching
    • Y Offline
      YannTKO @House Of Cards
      @wormuths Yes, it's just a display issue. You can check your data with vnstat in the shell. If you decide to change the data retention durations, it will affect your data and not only the display.
      Netgate SG-3100 23.09.1
      Unifi UAP: 1x FlexHD + 2x nanoHD + 1x AC-IW | Unifi USW: 1x16-PoE Gen2 + 4x US-8-60W | Cloudkey Gen2 Plus
      1 x NUC8i7BEH 32Go - ESXI 8 (Pfsense + many VM)
        mariyan
        @YannTKO, thank you very much for figuring a fix for those graphing issues.
          MyKroFt
          Can anyone generate a system > patches files.
          I am afraid i will really mess something up if I try manually changing files
          Myk
            MyKroFt
            Nobody?
              hulleyrob @pwnell
              @pwnell Thank you this fixed my current problem where the hourly graph looked like the first image since I did a fresh install of 2.4.5
              • MikeV7896M Offline
                MikeV7896
                Yeah, if this is an issue, someone should write up a bug in Redmine (use the pfSense Packages section and the Status Traffic Totals category) and then update the package in Github so everyone can benefit from the change and easily apply a system patch in the meantime. Manually changing files works great until a file you changed is updated, then your change disappears. At least a system patch can be re-applied without re-editing the file.
                The S in IOT stands for Security
                Y 1 Reply Last reply Reply Quote 0
                  hulleyrob
                  @pwnell said in Traffic Totals Hourly Report Problem:
                  value.time.hour
                  Just tried to create a pull request on GitHub what a mess that turned out to be. IF I have time later will try and do something in a non web version but that wasn't easy at all and it was a simple change to fix the hourly display on 2.4.5
                  • Y Offline
                    YannTKO @MikeV7896
                    @virgiliomi said in Traffic Totals Hourly Report Problem:
                    you can solve this issue by editing the file:
                    /usr/local/pkg/status_traffic_totals.inc
                    @YannTKO said in Traffic Totals Hourly Report Problem:
                    Beware, when you change your settings in traffic totals by the webgui and you save them as defaults, the file vnstat.conf is written again and you loose your data retention durations selection you choosed by editing this file.
                    If you want to keep your selection or your options, you must edit the file /usr/local/pkg/status_traffic_totals.inc
                    This one is used to create vnstat.conf
                    Yann.
                    • Y Offline
                      YannTKO @hulleyrob
                      @hulleyrob said in Traffic Totals Hourly Report Problem:
                      value.time.hour
                      It has been already done :
                      redmine.pfsense.org/issues/10429
                        Taz79
                        I have the same issues too... First i thought i was the only one to have issues until i saw this thread :) .. I just installed it and then removed it again when it turned out it was not working properly..
                          MyKroFt
                          guess I am dumb and dont understand what to change in this file, any push in the right direction?
                            hulleyrob @MyKroFt
                            @MyKroFt so you are happy to get to the file and edit it on the command line?
                            I just open it with VI find "value.id" this and the first line that matched was the one in the post above by @pwnell
                            "var date = Date.UTC(value.date.year, value.date.month-1, value.date.day, value.id);"
                            then edit value.id to value.time.hour
                            This fixed the hourly graphs for me which is all I was interested in. Save then quit and refresh the page job done.
                            • Y Offline
                              YannTKO
                              Editing /usr/local/pkg/status_traffic_totals.inc is just to keep data retention choice.
                              Editing status_traffic_totals.php is to solve the hourly/10 days graphical issues.
                              Yann.
                              H N 2 Replies Last reply Reply Quote 0
                                hulleyrob @YannTKO
                                @YannTKO sorry you are correct it was the PHP file I edited, early morning here coffee not kicked in yet.
                                  MyKroFt
                                  thank you, knowing it was the .php instead of .inc made sense and was able to edit the file
                                  thanks
                                    NinthWave @YannTKO
                                    @yanntko said in Traffic Totals Hourly Report Problem:
                                    Yann.
                                    Thank you for pointing me here.
                                    This thread as started in July and and the problem is stil pending ?
                                    I am in /user/local/pkg but there is no file status_traffic_totals.php
                                    • johnpozJ Online
                                      johnpoz LAYER 8 Global Moderator @NinthWave
                                      huh.. The file you want to edit is
                                      [2.4.5-RELEASE][admin@sg4860.local.lan]/usr/local/www: ls status_traffic_totals.php
                                      This looks like it was fixed back in nov
                                      https://github.com/pfsense/FreeBSD-ports/commit/dcb4949cc70f78006d05c662aa81c5849f93d4c0#diff-cbd6e5b8cd0fd83476715c17fdb47eec98bd0b54a6426f7dc7cfaeea141f7a4c
                                      But shows that it should be 2.3.2, but that is not what is being pulled down - only 2.3.1_1
                                      Without looking deeper - my guess would be that 2.3.2 is for 2.5 and not 2.4.5.. I fixed it with simple edit.. So I haven't really spent much time looking..
                                        NinthWave @johnpoz
                                        @johnpoz
                                        I have opened the php file but cannot find "HourlyDays".
                                        • johnpozJ Online
                                          No idea why you would think you would find anything like that?
                                          Look in the link I provided for exactly what needs to be changed.
                                            NinthWave @johnpoz
                                            @johnpoz
                                            I am sorry but GitHub is not my specialty. Is this a patch I am suppose to apply or edit the file munually ?
                                            I tried with the patch system and I get a reply that it cannot be applied safely.
