    DHCP minimum and maximum lease problem
    2 Posts 2 Posters 472 Views 2 Watching
      kutsheax
      Hi All,
      I have set my dhcp lease on the following setup:
      Minimum : 2 days
      Maximum 31 days
      These are my setting on the dhcp server:
      but on the UI lease status. this is what i see. The start and end seems abnormal. only 10minutes difference???
        Gertjan
        Release the lease for a device, use the release command.
        For windows, that will be
        ipconfig /release
        Then renew.
        Also, packet-capture the whole DHCP communication. Use wire-shark and friends to detail all the info.
        You'll see what will be asked for, and what the DHCP server (pfSense) is handing out.
        Another test :
        Disconnect all devices - rip out cables, shut down radio devices.
        Stop the DHCP server - all LAN type interfaces.
        Delete all the DHCP lease cache files : /var/dhcpd/var/db/
        Start DHCP server(s)
        And check.
        edit : and what devices ?
        Some just don't implement the DHCP protocol 'by the book'.
        What LAN ? Settings for the DHCP LAN server does not affect the settings of another LAN type (OPTx) interface.
