Bonding help between pfsense & Mikrotik SRS3xx (no vlan traffic passing?)
I'm wondering if anyone has experience creating an LACP bond between pfsense and a Mikrotik CRS3xx switch running RouterOS. I'm showing the bond as active but I can't get any VLAN traffic to pass across the bond. If I go down to just a single non-bonded port, traffic will pass fine.
That should work fine. I'm not sure if I've seen that specific switch but LACP to Microtik is quite common.
What about if you assign the lagg port dircetly? Can you pass traffic without the VLAN?
