    OpenVPN and Deutsche Glasfaser - IPV6 and CGNAT blocking connection?
    45 Posts 5 Posters 7.7k Views 5 Watching
      charry2014
      The site https://ipv6-test.com/ reports that my firewall is filtering ICMP v6 messages. Could this be a problem for OpenVPN? I am suspecting it might. How do I enable this?
      • Bob.DigB Offline
        Bob.Dig LAYER 8
        No. How is your IPv6 configured? I think your ISP is doing native IPv6.
          charry2014
          I think so too, but I am not sure of much from my ISP.
          One thing I did notice is that when I connect to whatismyipaddress.com or similar from different computers in my LAN that the IPv6 address that is returned is different for each one. The IPv4 address is the same, as I would expect. Now I think I am stumbling into a noob difference between IPv4 and IPv6 addresses.
          So the question - what actually is the IPv6 address of my PFSense WAN?
          • Bob.DigB Offline
            Bob.Dig LAYER 8
            You can see it in the interfaces-gadget and other places. 😉 (Status - Interfaces)
              charry2014
              Alright - so it is something like 2a00:61e0:abcd🔢:?
              It is not the much longer address 2a00:61e0:b00b5:34dd:6969:beef:babe:face?
              • Bob.DigB Offline
                Bob.Dig LAYER 8 @charry2014
                @charry2014 Can't say but maybe you did something wrong. Try this and go for DHCPv6 and not 6rd.
                  charry2014
                  Boom - that did it - using the IPv6 address for the WAN as shown in the Interfaces widget on the dashboard packets are now flowing.
                  I now get an authentication error, but the connection is there. Authentication errors are kinda the staple for getting OpenVPN working so somehow I am back on known territory now.
                  • JKnottJ Offline
                    JKnott @charry2014
                    @charry2014
                    No, OpenVPN uses UDP, not ICMPv6. However, ICMPv6 is used for a lot of things, so be careful about any rules blocking it.
                    UniFi AC-Lite access point
                    • JKnottJ Offline
                      JKnott @charry2014
                      @charry2014
                      One nice thing about IPv6 is there are plenty of addresses to go around. This means no longer having to share an address with NAT. Not only does each device get an address, it will often get several. With SLAAC, privacy addresses are often used. These are random number based addresses and you get a new one every day. They expire after a week. This is in addition to the consistent address, so you could have as many as 8 public addresses on each device.
                        charry2014
                        Thanks everyone for your help - it seems that a little background reading would be a good idea sometime soon. This may well change the settings in the firewall rules, then?
                        • JKnottJ Offline
                          JKnott @charry2014
                          @charry2014
                          That depends on what the rules do. If filtering on protocol, then you can often create a single rule that handles both. If filtering on address, then you'd need separate rules.
                            charry2014
                            So here it is, best I can remember it. All the things I changed to get this working:
                            System - Advanced - Networking
                            Interfaces - WAN
                            Interfaces - LAN:
                            The PFSense WAN IPv6 address is then in the Dashboard.
                            Finally I meant to link to beechy.de above but got the wrong link pasted in.
                            • JKnottJ Offline
                              JKnott @charry2014
                              @charry2014
                              That link @Bob-Dig provided says 6rd is going to be shut down, which means you should be configuring for DHCPv6 instead. My ISP did the same thing. They provided both 6rd and 6to4 tunnels, until they provided native IPv6 via DHCPv6-PD. This is what you should be configuring for, as that link describes.
                                charry2014
                                @Bob-Dig said in OpenVPN and Deutsche Glasfaser - IPV6 and CGNAT blocking connection?:
                                this
                                Feeling brave I tried DHCPv6 like suggested instead of 6rd and from a quick late-night hack it broke the IPv6 connectivity for me. This is one for more experimentation.
                                For the moment my pressing requirement is to fix my OpenVPN authentication issue rather than future-proofing the IPv6 connection.
                                  charry2014
                                  My authentication problems seem to be documented as a PFSense bug here so I have downgraded the login to SSL/TLS only and it works. Will keep researching the correct settings for DHCPv6. Cue small celebration here...
                                  One further question - is there any way I can access my home network over IPv4? This would be very handy, for one thing my employer only allows IPv4 traffic through their network, and I am sure to travel to corners of the world where the mobile network is not quite so modern as here. I have no idea what options there may be for this.
                                  • DerelictD Offline
                                    Derelict LAYER 8 Netgate
                                    If you mean connecting to your home network over an IPv4 tunnel, with IPv4 endpoints, probably not.
                                    Chattanooga, Tennessee, USA
                                    • JKnottJ Offline
                                      JKnott @charry2014
                                      @charry2014
                                      Not with that CGNAT address. Perhaps you could get an IPv6 tunnel from he.net. It will send IPv6 in IPv4 UDP packets, similar to that 6rd tunnel you were using. Then you'd use IPv6 to access your network.
                                      It sure will be nice when the world moves fully to IPv6, so that we can put all this NAT nonsense behind us.
                                      • DerelictD Offline
                                        I think he was asking about accessing his network from an IPv4 source. Seems he has IPv6 worked out.
                                          charry2014
                                          Exactly that - I am able to reach my home network when the remote device is on an IPv6 capable network but I am willing to bet that much of the world is still IPv4 only. From these networks I apparently have no possibility to establish a link home, which seems a bit of a problem.
                                          • JKnottJ Offline
                                            JKnott @charry2014
                                            @charry2014
                                            That is why I suggested he.net. They will provide IPv6 over IPv4, so that you can access IPv6 from an IPv4 only network. I haven't used he.net myself, but I used to use a 6in4 tunnel from another provider. With it, I could arrange for a /56 for a network a single IPv6 address for a device. I'd get a single address for my notebook computer, in addition to the /56 for my home network. I used a 6in4 tunnel for almost 6 years. Your ISP provided a 6rd tunnel, but I doubt it could be used off their network.
