    LAN, WAN and OPT1 OK ! Need help with OPT2-OPT3 and Ports !
    2 Posts 1 Posters 1.6k Views
      DouglasteR
      Hi my friends, after 2 weeks lurking tutorials and this forum threads i finally managed to get a Load Balance with 2 WAN's but my system has 1 LAN, 1 WAN and 3 OPT's.
      Interesting fact is that i cannot open any port in utorrent even after follow manu tutorials !
      So my problem is, the Pfsense and all conections are working fine, but load balancer is only using 2 WAN's (WAN + OPT1) and i can't open any ports.
      I've attached several pictures of the essencial part of the Pfsense setup.
      Menu.gif_thumb
      Load.gif_thumb
      LanWAN.gif_thumb
      Firewall_log.gif_thumb
      Rules_1.gif_thumb
      Rules_2.gif_thumb
      Rules_3.gif_thumb
      Rules_4.gif_thumb
      Rule_5.gif_thumb
      OPT1e2.gif_thumb
      OPT3.gif_thumb
        DouglasteR
        For those who readed my topic, my problem in this case is :
        Same Gateway in one OR more WAN´s.
        This cause the ARP Table to "see" only LAN, WAN and not any other WAN´s.
        This cause the Load Balancer to use only WAN + Lan (since my OPT´s have all the same gateway)
        the solution to my case is use an cisco 2900xl switch with VLan capabilites, i will create a VLAN to each of the gateways (even they being the same) ! wish me luck
