    help help to block anydesk
    4 Posts 3 Posters 2.0k Views 2 Watching
      kapvcop
      Hello friends, how can I block Anydesk, I have tried everything but without success, can you help me urgently, thank you very much
        What exactly have you tried? What was the result?
        If you have genuinely tried everything then there is nothing we can do, but I doubt you have. 😉
          kapvcop
          Hi, It is easy if on its official page it tells me how to open the ports, I apply it to the contrary, it should close it, on the other hand I have created blocks to the ports that the anydesk help page says but it does not work, that is, it continues to work, I have seen in another forum that the technicians ask for help just like me because they have not been able to do it, I think that if I knew the network segment that anydesk uses it could be useful ... however I decided to ask for help here too, I attach the page of the ports that says anydesk must be opened:
          https://support.anydesk.com/Firewall
          pttP 1 Reply Last reply Reply Quote 0
          • pttP Offline
            ptt Rebel Alliance @kapvcop
            @kapvcop said in help help to block anydesk:
            Show what you've done (screenshots)
