    Dual WAN load balance & failover problem
    3 Posts 2 Posters 2.3k Views
      benny_melb
      Hi all, i am new to this forum.
      recently i installed pfsense 1.2.2 onto one of my old pc with 3 NIC. Going to set it up as a load balancer & shapper (2WAN 1LAN).
      I follow the document below to setup my pfsense but the load balance & failover is not working  >.<
      http://doc.pfsense.org/index.php/MultiWanVersion1.2#Using_the_pfSense_Wizard
      Load Balancer Status showing both line is online. However, the traffic only goes to WAN2 and WAN1 is not contributing to the load balance.
      For the failover, I pull out the cat5 of WAN1 and the internet still working. I connected WAN1 back in and pull WAN2 out, the internet is down.
      Can anyone shed me some light on this one?
      Here is my setup
      P DNS:10.0.0.1
      S DNS:192.168.1.1
      Allow DNS server list to be overridden by DHCP/PPP on WAN = Enable
      WAN1 (ADSL)
      Static IP:10.0.0.2
      Gateway: 10.0.0.1
      WAN2 (ADSL)
      Static IP: 192.168.1.133
      Gateway: 192.168.1.1
      LAN IP: 192.168.11.1
      Sticky connection = Disable (Do i need to enable it?)
        benny_melb
        After playing around with the LAN rule and couple of reboot, both load balancing & failover is now working.
          kevindd992002
          I have three WAN setup and I can get load balancer to work properly but not failover.
          How did you setup yours? I hope you can help me. Thanks.
