    Vlan supported switch recommendation for Home
    26 Posts 10 Posters 7.3k Views 7 Watching
      gcu_greyarea
      I have one of those:
      https://buy.hpe.com/au/en/networking/switches/fixed-port-web-managed-ethernet-switches/1800-switch-products/hpe-officeconnect-1820-switch-series/hpe-officeconnect-1820-8g-poe-65w-switch/p/J9982A
      They come with limited lifetime warranty.
      Lightning struck our house and for some reason took out 1 Port.
      HP sent replacement switch within 2 days by UPS.
      If you don't need PoE get a J9979A
      • bingo600B Offline
        bingo600 @johnpoz
        @johnpoz said in Vlan supported switch recommendation for Home:
        The DGS-1100 series has web gui.. I have a -08 and never used their tool, only the web. You can use the tool if you want as well.
        +1 for the D-Link DGS1100-08 , for home usage
        And the 08P (PoE) is super too.
        It doesn't support 802.1x though, the DGS-1210-10 does
        Or the 1210-24 - Excellent as "Home core switch"
        /Bingo
        pfSense+ 23.05.1 (ZFS)
        QOTOM-Q355G4 Quad Lan.
          shetu @bingo600
          @bingo600 said in Vlan supported switch recommendation for Home:
          /Bingo
          DGS-1210-24 not available here but I see D-Link DGS-1210-28P 28-Port Gigabit Smart Managed Network Switch in some site.
          • bingo600B Offline
            bingo600 @shetu
            @shetu said in Vlan supported switch recommendation for Home:
            /Bingo
            28P = The P means PoE
            I would expect this unit to cost more than a non P, and that many PoE ports are prob not needed in a home setup.
            And as the PSU has to deliver a serious amount of PoE power , be prepared for Fan Noise.
            AFAIK the 08P is the only PoE (DGS model) wo. Fan.
            Edit:
            I use HP 1820-24 as "Core" switches at home.
            While they are ok , they lack a lot of the features (.1X , MAC ACL etc.) that the D-link 1210 series have , and cost about the same.
            I'd select 1210 today.
            I'd stay away from the small TP-Link's , they Vlan leak
            1210-24
            https://www.amazon.co.uk/D-Link-24-Port-Gigabit-Managed-DGS-1210-24/dp/B0036DRHHC
            Why's the -28 more expensive in US vs UK.
            https://www.amazon.co.uk/D-Link-28-Port-Gigabit-Switch-DGS-1210-28/dp/B008R7114W/
            /Bingo
            • bingo600B Offline
              bingo600 @johnpoz
              Did you mean to say 7.0 ? 6 is EOL, and quite old.. And sure doesn't actually support freebsd 11.x which is what current version of pfsense runs on..
              Re: 6.7 --> 7.0
              I have 2 small VMware "Free" installs at home (6.7) , and just checkked 6.7 --> 7.0.
              My machines are for small linux VM's , Core-I3's w. 16G Ram , and Realtek Network Cards. Where i have "sneaked" an older Realtek NIC driver into the system.
              Realtek NIC support is not possible on 7.0, as the old Linux driver subsystem, has been taken out of 7.0.
              So i'll guess i stay on 6.7 for my installs
              Good info
              https://www.virtuallyghetto.com/2020/03/homelab-considerations-for-vsphere-7.html
              Just a general info for those having a little "box w. Realtek"
              I wouldn't have run pfSense on those anyway
              • V Offline
                Vollans
                I’m happily using Netgear Insight switches (GC728X and 2 GC110) at home and if you ignore the insight app the web interface is great and far more fully featured. Even the GC110 with 8 RJ45 and 2 SFP ports do LAG, VLANs, IGMP snooping, etc. They often seem to be on sale at Amazon at stupid prices - which is when I’ve bought them.
