Wrong limiter speed
@bobbenheim
i look at the link you send me
hw.em.eee_setting="0"
mean that energy is enabled
to be at full (no Energy Efficient Ethernet) always should it be disable =1
to force the nic to be at maximum !?? -
@Jimbohello Didn't take notice of that, but you can give it a try and change it back to see if it makes a difference. But so far it seems that a lot of people have misunderstood that one if "1" is disable, i wouldn't know since i don't use the em driver and therefore haven't tested it.
@bobbenheim
because i'm french
correct me if i'm wronghttps://www.freebsd.org/cgi/man.cgi?em(4)
hw.em.eee_setting Disable or enable Energy Efficient Ethernet. Default 1 (dis- abled).so 1 = disabled
wright ?? -
@Jimbohello yes i would interpret it that way
@bobbenheim
What's up BOB !
/boot/loader.conf.local - final - best result ever !
if_em_load="YES"
cc_htcp_load="YES"
hw.em.rx_process_limit="-1"
hw.em.txd="2048"
hw.em.rxd="2048"
net.link.ifqmaxlen="4096"4 computer downloading debian iso 4.4 gig
RTT never moved 0.6ms
RTTsd never moved 0.2ms
Lost 0.0 %this is far the best config ever
limiter config Download
Codel
FQ_codel
queue lenght 100
ecn enablelimiter Queue Download
Mask / Destination Adresse /32
Codellimiter config Upload
Codel
FQ_codel
queue lenght 100
ecn enablelimiter Queue Upload
Mask / Source Adresse /32
Codellimiter on lan rules
in= upload-queue
out=download-queuewith all helps ! all people sharing knoledge ! everything's possible!
Thank you so muck
