    Speed issues PPPoE
    40 Posts 7 Posters 13.0k Views 9 Watching
    • L Offline
      Lieven
      I've been looking for a while now for a solution, but haven't found a thing...
      When I use the modem provided from my provider, pfsense connected to that network by the WAN port (DHCP) I reach speeds arround 50Mbs.
      However when I set the WAN as PPPoE, I only get a speed of 8Mbs.
      Is there a solution to this problem?
      • DaddyGoD Offline
        DaddyGo @Lieven
        @Lieven said in Speed issues PPPoE:
        PPPoE is preferred by ISPs (in many more places) for identification and parameterization.
        PPPoE is a tunnel protocol...
        It is always slower than an identical Dynamic IP (DHCP), IPoE, fixed IP solution.
        Oddly enough, the big difference is 50/8 this is not typical
        Does your ISP have any diferrent settings (bandwidth) for PPPoE connection and DHCP?
        You may want to try connecting directly to your ISP device with a laptop or other option and measure the speed for PPPoE and DHCP.
        +++edit:
        otherwise in front of the firewall I would avoid PPPoE especially, if you have DHCP capability.
        PPPoE only complicates your life
        JKnottJ L 2 Replies Last reply Reply Quote 0
        • JKnottJ Offline
          JKnott @DaddyGo
          @DaddyGo
          In my experience your choices are either DHCP or PPPoE depending on the provider and you can't just pick one. PPPoE adds an 8 byte header, resulting in the 1492 MTU. Those 8 bytes should cause only a slight decrease in throughput. PPPoE is generally used with ADSL and DHCP with cable. With ADSL, you're much more likely to see a decrease due to the line quality and distance.
          UniFi AC-Lite access point
          • DaddyGoD Offline
            DaddyGo @JKnott
            @JKnott said in Speed issues PPPoE:
            It was not me who wrote that I had both methods, this was written by OP ๐Ÿ˜‰
            Strange to me too.
            Btw: It is not generalizable to be ADSL + PPPoE, but they can actually be connected.
            We have now terminated the PPPoE connection of one of our GPON subscriptions because there were constant problems with Snort.
            Now the same optical fiber (GPON) is running on a fixed IP and Snort is satisfied, no tunnel protocol.
            Indeed the speed reduction, as I have written, should not be significant. PPPoE vs. Dynamic IP, but exists especially at high loads.
            Not to the same extent as for OP.
            Currently, PPPoE and fixed IP are still available on our GPON connection
            the figure shows that we get the maximum out of 1000/400 with the fixed IP, but with PPPoE the reach is slower than by 6-8%.
            Nearly 50 IceCast2 servers with 2,000 to 2,500 listeners run daily on this connection.
            • JKnottJ Offline
              JKnott @DaddyGo
              @DaddyGo
              If you're seeing a problem with PPPoE, it's elsewhere, not with the protocol, as it takes only 8 bytes from the frame. As for GPON, if it comes from a phone company, it will likely use PPPoE, as they use on ADSL. If DHCP, then it's likely a cable TV company, as they generally use. You can get static from either.
              BTW, I have set up many business customers over ADSL, SDSL, cable and fibre, with static or dynamic addresses. I have even set up some with PPP over fractional T1, through a CSU.
              • DaddyGoD Offline
                DaddyGo @JKnott
                You know, the joke is that in this area we are the ISP and cable TV and FM URH radio broadcast service provider.
                Only another department is dealing with it GPON / DOCSIS systems.
                We have not used ADSL / VDSL for a thousand million years.
                I am well acquainted with the PPPoE protocol and "I am in the picture", but thanks for the ongoing clarification and confirmation...๐Ÿ˜‰ (MTU, etc.)
                btw:
                In the EU, very serious investments have been made in broadband internet infrastructure, so most Member States have optics and DOCSIS.
                You can check **ASN 59869 that is the block of our Hungarian company.
                (although I work in the Western European division)
                +++edit:
                yeah, what I forgot to repeat, weโ€™re not talking about a significant difference...
                and under a very serious load - under the same conditions (GPON) - only protocols differ
                as:
                50 pcs. IceCast2 stream with 320 mp3 CBR - 2000 - 2500 user
                  I think what the OP is saying here is that they get full 50Mbps if they allow the ISP provided device to do the PPPoE and connect to that from pfSense with DHCP.
                  I would expect to get the same speed using PPPoE directly from pfSense assuming the correct parameters are used.
                  Some ISPs will allow you to connect but at a much reduced rate if you do have the correct VLAN or priority set. Or the correct login even.
                  • L Offline
                    Lieven @DaddyGo
                    @DaddyGo
                    Maybe I was not clear enough in my description.
                    When I connect Pfsense by PPPoE, I get slow speeds.
                    When I set the WAN interface to DHCP, I get an IP from the modem of my provider. On its local network. The modem itself connects also by PPPoE.
                    The reason I want to use PPPoE is because on the modem I adjust certain settings to be able to remotely access my network.
                    DaddyGoD JKnottJ 2 Replies Last reply Reply Quote 0
                    • L Offline
                      Lieven @stephenw10
                      Yes Stephen, that's exactly my problem.
                      @stephenw10 said in Speed issues PPPoE:
                      So you think that maby not all parameters are set correctly then? I must say I didn't think about the VLAN and priority settings. But also have no idea at the moment where to set these in pfSense.
                      I'll see what I can do about that this evening.
                      • DaddyGoD Offline
                        DaddyGo @Lieven
                        @Lieven
                        Now it is clear... THX
                        • JKnottJ Offline
                          JKnott @Lieven
                          You don't use PPPoE on the LAN side of the modem. That's only used from the modem back to the ISP. Years ago, you'd configure computers for PPPoE, as the modem didn't do it. If you're using it on a modem that's already using it, it's no wonder you're having problems.
                          • L Offline
                            Lieven @JKnott
                            @JKnott I understand.
                            But... The modem is configured as passthrough. So theoretically it should be the same connecting straight to the ISP. (right?)
                            Also, everything works, I get an IP, having internet,... But only slower speed.
                            The other problem is that on my pfSense, I do not have an RJ11 connection. (connection to ISP) So connecting it to the ISP without the modem is not possible.
                            Also I still need the modem for my TV, so I cannot eliminate it completely...
                            • DaddyGoD Offline
                              DaddyGo @Lieven
                              Because there is no ADSL modem built into pfSense
                              The RJ11 connector standard is POTS or ISDN 2 wire or 4 wire
                              So this is a separate theme...
                              • L Offline
                                Lieven @DaddyGo
                                @DaddyGo said in Speed issues PPPoE:
                                I agree, so I still need the modem...
                                But how can I find out what's slowing down my connection?
                                This evening I will settup the same PPPoE connection from my PC. If it is also slow, then the modem is the cause. If it's high speed, it's pfSense...
                                (Why didn't I think about this sooner...?)
                                • DaddyGoD Offline
                                  DaddyGo @Lieven
                                  @Lieven
                                  if you look, I have already suggested this above...๐Ÿ˜‰
                                  "You may want to try connecting directly to your ISP device with a laptop or other option and measure the speed for PPPoE and DHCP."
                                  • L Offline
                                    Lieven @DaddyGo
                                    @Lieven
                                    Yeah, for some reason I did't connect the correct dots in my head... Maybe to busy with working...? ๐Ÿค”
                                    I'll try this evening!!
                                    • JKnottJ Offline
                                      JKnott @Lieven
                                      Not necessarily. I have set up ADSL modems in pass through, but they still did PPPoE back to the ISP. It's been many, many years since the last time I had to configure PPPoE on a computer. If you get a working Internet connection when using DHCP on the LAN side, you can be certain the modem is already using PPPoE. Your performance issue is proof of that.
                                        PPPoE WAN connections in pfSense are very common. Both of mine are that. Both are connected to an upstream DSL modem in pass-through mode.
                                        However modems configured like that may or may not apply the required VLAN settings. In my case here in the UK most DSL providers require VLAN 101 and the modems do that by default so pfSense just uses PPPoE untagged.
                                        Yes, try connecting a laptop to the modem directly and establishing a PPPoE session form there. If you still get limited speed then you are probably missing some connection parameter. Who is your ISP.
                                        • L Offline
                                          Lieven @stephenw10
                                          I tried following setups:
                                          1. modem connects to ISP by PPPoE and pfSense to modem by DHCP/fixed IP = 50Mbps
                                          2. modem connects to ISP by PPPoE and PC to modem by DHCP/fixed IP = 50Mbps
                                          3. PC connects to ISP by PPPoE (physically with modem in between) = 50Mbps
                                          4. pfSense connects to ISP by PPPoE (physically with modem in between) = 16Mbps
                                          So it is only with pfSense in combination with PPPoE that I experience slow speeds.
                                          I'm located in Belgium
                                          ISP is Proximus
                                            Hmm, that's fun!
                                            Is it actually linked to the modem correctly? What does ifconfig -a show about the PPPoE parent interface when it's connected?
                                            It could be something simple like a bad cable.
                                            Try putting a switch in between the modem and pfSense as a test if you can.
