    How to run a Bashtop or top after system rebooting, right after general menu (in Console) ?
    11 Posts 3 Posters 553 Views 3 Watching
    • Sergei_ShablovskyS Offline
      Sergei_Shablovsky
      Hi, pfSense Gurus!
      How to run a bashtop / top after system rebooting, right after general menu (in Console).
      I mean like You logging locally on Console Port or via Rack Terminal (Keyboard + Monitor) locally attached, and after successfully booting press "8" to loading Shell, and after loading "bashtop" or "top".
      And additional question are "How to add extra one item (for example "Top") to general menu (in Console) for quickly launching "bashtop" or "top"?
      May be solution are editing /etc/rc.initial ?
      Thank You for help and suggestions! Have a nice sunny day!
      CLOSE SKY FOR UKRAINE https://youtu.be/_tU1i8VAdCo !
      Help Ukraine to resist, save civilians people’s lives !
      (Take an active part in public protests, push on Your country’s politics, congressmans, mass media, leaders of opinion.)
        Sergei_Shablovsky
        Or using shellcmd option (described in https://docs.netgate.com/pfsense/en/latest/development/boot-commands.html#shellcmd-option) to start top?
          Gertjan
          When you login, you're in front of the screen, right ?
          As SSH access needs a cert password to be typed in, what's against an extra 8 + enter + top + enter ?
          @Sergei_Shablovsky said in How to run a top after system rebooting, right after general menu (in Console) ?:
          You tried it ?
          top would start, find out it wasn't started using an interactive shell, so it quiet ... or refreshing the list it can't show, only eating system resources in the back ground.
          Sergei_ShablovskyS 1 Reply Last reply Reply Quote 0
            You could just patch rc.initial. Can be a hidden option, like 101 say:
            101)
            	/usr/bin/top -aSH
            *** Welcome to pfSense 2.4.5-RELEASE-p1 (amd64) on 244dev ***
             WAN (wan)       -> vtnet0     -> v4/DHCP4: 172.21.16.180/24
             LAN (lan)       -> vtnet1     -> v4: 192.168.180.1/24
             OPT1 (opt1)     -> vtnet2     -> v4: 192.168.56.1/24
             0) Logout (SSH only)                  9) pfTop
             1) Assign Interfaces                 10) Filter Logs
             2) Set interface(s) IP address       11) Restart webConfigurator
             3) Reset webConfigurator password    12) PHP shell + pfSense tools
             4) Reset to factory defaults         13) Update from console
             5) Reboot system                     14) Disable Secure Shell (sshd)
             6) Halt system                       15) Restore recent configuration
             7) Ping host                         16) Restart PHP-FPM
             8) Shell
            Enter an option: 101
            last pid: 73892;  load averages:  0.09,  0.14,  0.12    up 0+00:56:00  15:57:36
            168 processes: 2 running, 140 sleeping, 26 waiting
            CPU:  0.0% user,  0.0% nice,  0.0% system,  0.0% interrupt,  100% idle
            Mem: 65M Active, 75M Inact, 192M Wired, 38M Buf, 1608M Free
            Swap: 512M Total, 512M Free
              PID USERNAME   PRI NICE   SIZE    RES STATE    TIME    WCPU COMMAND
               11 root       155 ki31     0K    16K RUN     54:42  99.79% [idle]
               12 root       -60    -     0K   416K WAIT     0:03   0.06% [intr{swi4: clock
            73892 root        22    0  7824K  4124K RUN      0:00   0.04% /usr/bin/top -aSH
               12 root       -92    -     0K   416K WAIT     0:01   0.01% [intr{irq261: vir
            31602 dhcpd       20    0 16464K 10120K select   0:00   0.01% /usr/local/sbin/d
                7 root       -16    -     0K    16K -        0:00   0.01% [rand_harvestq]
                6 root       -16    -     0K    16K pftm     0:00   0.01% [pf purge]
            83336 root        20    0  6908K  2316K nanslp   0:00   0.01% /usr/local/bin/dp
            83047 root        20    0  6908K  2316K nanslp   0:00   0.01% /usr/local/bin/dp
            68769 root        20    0 12968K  7792K select   0:00   0.01% sshd: admin@pts/0
            83336 root        20    0  6908K  2316K sbwait   0:00   0.00% /usr/local/bin/dp
              337 root        20    0 94900K 25260K kqread   0:00   0.00% php-fpm: master p
            25259 root        20    0 10420K  5680K select   0:00   0.00% /usr/local/sbin/n
            83047 root        20    0  6908K  2316K sbwait   0:00   0.00% /usr/local/bin/dp
            53271 root        20    0  6968K  2692K bpf      0:00   0.00% /usr/local/sbin/f
               22 root        20    -     0K    32K sdflus   0:00   0.00% [bufdaemon{/ work
            It would get overwritten so you'd probably want to use an actual patch applied via the patches package.
              Sergei_Shablovsky @Gertjan
              @Gertjan said in How to run a bashtop or top after system rebooting, right after general menu (in Console) ?:
              You tried it ?
              Thank You for suggesting!
              I am not sure that I clearly understanding You.
              I just need after hardware “cool restart” (watchdog in UEFI, or in separate Hardware Monitoring pcb, or after power failure and reestablish) and bsd/pfSense start, AUTOMATICALLY going to console menu and start Bashtop item.
              Just like this happened now, but AUTOMATICALLY go to certain menu item (in my case Bash).
                Sergei_Shablovsky @stephenw10
                @stephenw10 said in How to run a bashtop or top after system rebooting, right after general menu (in Console) ?:
                101)
                	/usr/bin/top -aSH
                Thank You for help!
                Now I have 2 questions:
                Why I need “hidden” option instead to creat normal menu item by editing original rc.initial file?
                Please point me on User Manual that describe how to make the “patches package”. And how to make applying my custom “patches package(s)” each time after pfSense update (no matter what way from webgui or console)?
                  It doesn't have to be hidden you just have that option.
                  You need to create a diff file and then you can import that as a patch into the patches package.
                  I would create that by forking it on github and editing it. That will create the diff for you and give you a convenient commit url to import.
                  For example:
                  https://github.com/stephenw10/pfsense/commit/e66cd5949ee8a0c4d0c7c8d7c3bbfe1ed550da64
                    For example:
                    Ok, I understand how to create a patch from diff.
                    What a You suggest about how to automatically apply this “my patch” after each pfSense update ?
                    And back to topic, how to automatically start Bashtop/top/whatever from menu after pfSense loading? (Like local operator choose menu item in VGA console)
                      The patches packages has an option to 'auto apply' patches.
                      Adding those options to the rc.initial menu starts them from there. Just enter the menu number like any of the other entries.
                        Thank You, Steve!
                        Sorry my stupidness today, where in code I must insert to automatically start certain menu item ? (And I hope after Ctrl+C/Q/Esc, back to main rc.initial menu. Like, I start, let’s to say, “Ping host” and then back to rc.initial menu after exit from rc.initial.ping)
                          Ah, I haven't tried starting one of the options by default, without selecting something. I'm not sure how that would work if there wasn't actually a console attached.
                          But it's just a shell script, you can have it do whatever you can code it to.
