Problem with IPSEC between Pfsense 2.4.5 and Cisco ASA
Hello
I have established an IPSEC tunnel between a Pfsense 2.4.5 and a Cisco ASA, but I have a problem with phase 2.
I set up 5 phase 2 with the same LAN on my side but 5 other networks for the neighbor.
On these 5 networks, only 4 are working and on IPSEC status I actually see only 4 entries SA CHILD.
When I remove all phase 2 except the one that does not work the tunnel is established well with the previous network that does not work.
I have activated the following features but nothing changes:
- Cisco Extensions
- Split connections
Have you ever encountered a phenomenon of this type and do you know the reason for this problem ?
