    Need help with my VLAN firewall rules to make sure they do what I think they do
    69 Posts 5 Posters 5.0k Views 4 Watching
    • I Offline
      imthenachoman @johnpoz
      @johnpoz
      Yes but it wasn't doing what I was expecting.
      I would have expected the FW rule I circled (the port forwarding of DNS from LAN to pfSense) to be triggered. But it wasn't and so the catch all rule was catching it.
      But I figured out the issue and created a FW rule to allow traffic from LAN net to LAN net on 53. That rule is triggering for the client DNS queries -- so I don't need the catch all.
      Not that you asked, but if you're curious, I've been making notes for myself and decided to put it in a public gist to hopefully help others out. https://gist.github.com/imthenachoman/67ca5f0cb747b680ca4a44abdc564b20
        johnpoz LAYER 8 Global Moderator @imthenachoman
        @imthenachoman said in Need help with my VLAN firewall rules to make sure they do what I think they do:
        Rule doesn't make a lot of sense.. If you want to allow access to lan address, then allow that.. lan net as destination on the lan interface makes no sense..
        Lan can already talk to anything else on the lan, devices on lan don't talk to pfsense to talk to other stuff on lan. So lan net as destination makes no sense on the lan interface. Lan address is a destination that makes sense, stuff other than lan make sense..
        We already went over why your circled rule wouldn't match..
        Not sure where you got the idea that everything needs to be redirect to pfsense. Are you not handing them already.. If you don't want things talking to other than pfsense for dns or ntp. Block it I think is better.
        Would you like it if your isp said, hey you know what we don't want clients using google - so lets redirect them so they think they are talking to google, but they will really be talking to us.
        Redirection can be a solution to a problem - where client X doesn't listen to what you you hand him via dhcp, or set on him directly.. Personally I think its a bad idea to do as some sort of standard.. I would say a block rule is prob better than you log, so you can see hey this client I hand pfsense for dns, why does he continue to bang his head trying to query google for xyz.tld..
        I 2 Replies Last reply Reply Quote 1
        • I Offline
          @johnpoz
          I want to have very tight control of what traffic is allowed where. I don't want any kind of "default allow all" rule or anything.
          So, my understanding is, LAN net is 192.168.1.1, right? That is also what clients on LAN get for the DNS server. So when said clients want to do a DNS query they send it to 192.168.1.1:53. Am I right so far?
          So if I want traffic from the LAN clients coming through LAN net to be able to make DNS queries to 192.168.1.1:53, or LAN net:53, then I need a FW rule saying traffic from LAN net to LAN net:53 is allowed. Right?
          Why is it not better to have a central authority for all DNS queries on my network? That way those queries are cached. So if system1 looks up example.com, when system2 looks it up, pfSense can return a cached response. Isn't that good/desirable?
          • I Offline
            @johnpoz
            I wager most folks disagree with me for having excessively strict rules. I'd be willing to debate/discuss it with someone but I much prefer the policy of only allowing exactly what is needed, nothing more, nothing less.
              netblues
              LAN address is the address of the interface of the pfSense to the LAN. (ie. 192.168.1.1/32)
              LAN subnet is the subnet attached to this interface. (ie. 192.168.1.0/24)
              As for caching of dns, well, unbound is bound to all running interfaces, so this will happen by default, without any redirects.
              If you are using pfblockerng, then yes, you probably want some control over external dns access
              Having total control is nice, but it also means to be constantly adjusting things.
              Its nice as an exercise, but doing that in a home network with demanding users (aka kids) is kinda of a full time job.
              • bingo600B Offline
                bingo600 @imthenachoman
                Re: Lan net vs Lan address (pulldown selections)
                Lan address is the specific interface adresss : ie. 192.168.1.1
                Lan net is the defined network : ie. 192.168.1.0/24
                For allowing any (on the Lan) to send DNS req. to the interface i would do.
                IF : LAN
                AF: IPv4
                Proto: TCP/UDP
                SRC: Lan net
                Dest: Lan address (Only matches The interface ip)
                Port: DNS
                Allow Lan Net to Lan Net , would only be effective if the dest-ip was the Lan interface, as all other packets sent between devices on the same "subnet" would be sent directly between the devices. And not pass the firewall. Hence the rule would be better indicating : LanNet to Lan address (interface ip)
                Btw: I totally agree with @netblues , that only allowing specific permits , on a "general use" subnet. Would be a steady job.
                pfSense+ 23.05.1 (ZFS)
                QOTOM-Q355G4 Quad Lan.
                • bingo600B Offline
                  bingo600
                  Btw:
                  Only allow DNS requests to "Lan address" seems a bit contradictive , with the purpose of the "DNS forward rule".
                  The forward rule (Catch all DNS) , is usually made in order to catch programs/apps that uses "hardcoded" or custom DNS servers. Ie. a Google app that tried to resolve DNS via 8.8.8.8.
                  If DNS to "any" was allowed (while the DNS forward rule was in place) , the request to 8.8.8.8 would be rewritten to 127.0.0.1 once the package was entering the pfSense , and the APP would still get a DNS answer (from pfSense).
                  If you only allow DNS to the LAN address (interface) the request to 8.8.8.8 would just be dropped.
                  It depends on what you want .....
                  I only allow DNS to my "interface" , and all(most) all apps that tries a "foreign" DNS , will fall back to the DNS given by DHCP.
                  But it will break Ie. PI-Hole updates , as they now relies on SRV records from a specific DNS server , to inform about supported OS'es. And the forward "trick" would also break it.
                  I think i have 2..3 apps that are misbehaving if not allowed to their native DNS. I can live with those limitations.
                  /Bingo
                    johnpoz LAYER 8 Global Moderator @bingo600
                    @bingo600 said in Need help with my VLAN firewall rules to make sure they do what I think they do:
                    huh/what?? That is not how it works..
                    Your saying pihole has to talk to a specific NS or it can't update??
                      @imthenachoman
                      Not saying you can not stop something from talking to DNS you don't want it to - my point is redirection of traffic hiding from the client that it not talking to who it thinks it is talking to is not good practice.
                      You sure and the F would not like it if your isp did it to you.. While its your network and you can do what you want. It amounts to the pot calling the kettle.
                      If you don't want something talking to outside dns, then block it sure.. But redirection is not good idea if you ask me..
                      • bingo600B Offline
                        bingo600 @johnpoz
                        @johnpoz said in Need help with my VLAN firewall rules to make sure they do what I think they do:
                        Yup
                        https://github.com/pi-hole/pi-hole/issues/3694
                        Somehow it won't (in default config) accept my DEB10 as a valid OS , unless i permit access to : ns1.pi-hole.net / 185.136.96.96 (for Update)
                        A workaround would be this : PIHOLE_SKIP_OS_CHECK=true
                        So DNS is being (mis)Used for lot's of tricks.
                        And it is how it works (for pihole update)
                        Edit:
                        pihole-check Git commmit
                        https://github.com/pi-hole/pi-hole/commit/0ff32c3629220f386a45c14d8982aaaf128aa47f
                        I didn't dig deeper , as i just did a temporary permit during the update.
                        Edit2: Seems to be a TXT not SRV (my bad)
                        /Bingo
                          Yeah I agree with the comments on that - that is a HORRIBLE solution to an issue of some local dns sucking..
                          Looks like they are changing it to output info, for those that block dns..
                          Since when does MS dns fail to return txt records? I don't see any SRV mentioned in that?
                          bingo600B 1 Reply Last reply Reply Quote 1
                          • bingo600B Offline
                            bingo600 @johnpoz
                            @johnpoz
                            My bad assumed they used a SRV not a TXT
                            • bingo600B Offline
                              bingo600
                              My main dns'es are two local bind9 servers.
                              Everything else , including pihole & unbound uses those
                              Primary reason i had them running before pfSense was installed.
                              Use them for DNS & DHCP , and get the full ISC features.
                              And i can do dynamic DHCP updates wo. the dreaded unbound dead time
                                My pihole is currently up to date..
                                root@pi-hole:/home/pi# pihole -up
                                  [i] Checking for updates...
                                  [i] Pi-hole Core:     up to date
                                  [i] Web Interface:    up to date
                                  [i] FTL:              up to date
                                  [āœ“] Everything is up to date!
                                But I will for sure try and test this next time an update is out.. I have just added a block any other dns on the piholes vlan.. I was blocking dot and doh.. It didn't attempt to check any other dns when I asked it to see if update - but maybe it only does that if there is an update?
                                bingo600B 2 Replies Last reply Reply Quote 0
                                • I Offline
                                  imthenachoman @bingo600
                                  Oh! I see my mistake now.
                                  IF : LAN
                                  AF: IPv4
                                  Proto: TCP/UDP
                                  SRC: Lan net
                                  Port: DNS
                                  Awesome. Thank you!
                                  Wouldn't a port forward rule take care of this? Any request from a client on :53 gets redirected to 127.0.0.1 (pfSense)?
                                  Totally fair. But as I am just starting out in my journey, I will set it like this for a while and see how ti works. I'll redo everything in a few months anyway -- once I understand things better -- and then I'll see how I set up my DNS.
                                  I really do appreciate all of the time y'all have been putting in to help me. I am a big fan/supporter of paying those who help when I can. Teachers in schools get paid, so should teachers elsewhere. LMK if I can return the fair monetarily.
                                  Also, Happy Holidays everyone!
                                  • bingo600B Offline
                                    bingo600 @johnpoz
                                    @johnpoz
                                    I have localhost as resolver on the pihole DEB10
                                    dns-nameservers 127.0.0.1
                                    And pihole is using my bind9's as upstream resolvers (on the same L2) - That failed during the updates.
                                    Then i made a specific allow pihole/32 to any - dns
                                    And it updated.
                                    After update i disabled that one again
                                    • bingo600B Offline
                                      My (adequate) payment is to know i helped someone else that has an issue. - We have all been there.
                                      And i hope they will help someone else in the same way.
                                      You too
                                      Edit: There is an implicit "thank you" method here on the forum.
                                      Click the "Thumbs up icon" in the bottom of the post you like.
                                      That gives the poster a +1 on helpfull posts.
                                      /Bingo
                                      • bingo600B Offline
                                        bingo600 @johnpoz
                                        @johnpoz
                                        I have been a naughty boy 😧
                                        And hadn't updated mine.
                                        Here's a "sniff" of my pihole ip , w. port 53 tcp/udp during a "NS1 allowed" update.
                                        Wo. allowing "NS1" it barfs.
                                        /Bingo
                                          Why are they doing a directed query? What reason is given - that AD or MS dns does not allow for TXT queries? That is utter BS plain and simple..
                                          I am not buying the reason for doing this at all..
                                          • bingo600B Offline
                                            bingo600 @johnpoz
                                            @johnpoz
                                            I don't have anything w M$ DNS
                                            If you do you could try the dig they use here.
                                            If working it should give the same answer as in my sniff above i suppose.
                                            Or the pcap here
