    Need help with my VLAN firewall rules to make sure they do what I think they do
    69 Posts 5 Posters 5.0k Views 4 Watching
    • bingo600B Offline
      bingo600 @johnpoz
      @johnpoz
      Did you find the git PR that shows the cookie issue ?
      I had a brief look , but didn't find any.
      /Bingo
      pfSense+ 23.05.1 (ZFS)
      QOTOM-Q355G4 Quad Lan.
      • bingo600B Offline
        bingo600
        Ahh think it's this one
        (Win SRV 2008R2) , that is even out of support ... Grrrrr
        https://github.com/pi-hole/pi-hole/issues/3578
        That leads to this one
        https://github.com/pi-hole/pi-hole/issues/3595
        That even contains
        Try with dig +nocookie -t txt versions.pi-hole.net
        Sigh .... Redmond again šŸ¤’
          johnpoz LAYER 8 Global Moderator @bingo600
          Yeah and it was with 2008r2 that is DEAD... full end of life was jan 2020, so why would they be doing something to work around an issue with that in july of 2020?
          All seems a bit stupid to me..
          I bingo600B 2 Replies Last reply Reply Quote 0
          • I Offline
            imthenachoman @johnpoz
            @johnpoz @bingo600 A lot of what y'all are saying is going way over my head. I am trying to decode/translate for myself. It sounds like y'all are talking about something specific to pi hole -- is that right? Just so I can better understand the conversation...
            • bingo600B Offline
              bingo600 @imthenachoman
              @imthenachoman
              Yes .. We're talking about pi-hole , and DNS blocking.
              And that pi-hole won't update if you block DNS to anything but the pfSense.
              • I Offline
                imthenachoman @bingo600
                @bingo600 I see. Interesting. Thanks!
                • bingo600B Offline
                  bingo600 @johnpoz
                  @johnpoz
                  I just got a new update for my pihole, i suppose you ought to see it too
                  This time i tried
                  PIHOLE_SKIP_OS_CHECK=true sudo -E pihole -r
                  Selected repair , and the update went through wo. opening for ns1
                  But damm annoying 😠 šŸ‘Ž
                    Looks like an update to FTL.. lets see what happens.. I have these rules in place..
                    For the vlan that my pihole sits on..
                    Yeah this is nonsense...
                     [āœ—] Retrieval of supported OS list failed. dig failed with return code 9.
                          Unable to determine if the detected OS (Raspbian 10) is supported
                          Possible causes for this include:
                            - Firewall blocking certain DNS lookups from Pi-hole device
                            - ns1.pi-hole.net being blocked (required to obtain TXT record from versions.pi-hole.net containing supported operating systems)
                            - Other internet connectivity issues
                    This is zero issue with grabbing that info.. Other that you forcing a direct query to ns1.. Gawd this just pisses me off that they do nonsense like this.. Arrrghh.. Why are people so freaking stupid?????
                    root@pi-hole:/home/pi# dig versions.pi-hole.net txt
                    ; <<>> DiG 9.11.5-P4-5.1+deb10u2-Raspbian <<>> versions.pi-hole.net txt
                    ;; global options: +cmd
                    ;; Got answer:
                    ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 16772
                    ;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
                    ;; OPT PSEUDOSECTION:
                    ;; QUESTION SECTION:
                    ;versions.pi-hole.net.          IN      TXT
                    ;; ANSWER SECTION:
                    versions.pi-hole.net.   3600    IN      TXT     "Raspbian=9,10 Ubuntu=16,18,20 Debian=9,10 Fedora=31,32 CentOS=7,8"
                    ;; Query time: 356 msec
                    ;; SERVER: 127.0.0.1#53(127.0.0.1)
                    ;; WHEN: Sat Dec 26 19:21:24 CST 2020
                    ;; MSG SIZE  rcvd: 127
                    So they fixed working with some antiquated dns windows server 2008??? That is EOL!!! By just bypassing it. To break everyone else that would be filtering dns other than their own.. Ie pretty much every pihole user on the planet ;) This is just some of the stupidest shit ever.. WTF!!!
                    While I am a fan of pihole - this is just borked.. Same goes with some of the nonsense they are trying to do with dnssec.. If your going to forward, dnssec is pointless - he doesn't get that either.. Maybe we should fork their code ;)
                    • bingo600B Offline
                      bingo600 @johnpoz
                      @johnpoz said in Need help with my VLAN firewall rules to make sure they do what I think they do:
                      Totally agree .. Fix for an old outdated OS , and "bork" everyone else.
                      I thought they wouldn't touch DoH at all as "PH is not a security product"
                      He..He
                      Intriquing , but i doubt i have time for that.
                      /Bingo
