    Two WAN addresses and strange connection failing problem
    2 Posts 1 Posters 437 Views 1 Watching
      joukahainen
      My setup is as follows.
      Two LAN cards, both getting IP with DHCP trough cable modem, like this:
      1_WAN_DEFAULT 1000baseT <full-duplex> xx.152.87.5x Workstations
      1_WAN_PUBLIC 1000baseT <full-duplex> xx.157.212.1xx Servers
      Everything works fine, except now and then, the public network connection to servers I am hosting in WAN_Public fails for 30-45 minutes.
      When this happens, I can see in firewall logs blocking messages like this:
      Mar 2 13:26:07 1_WAN_DEFAULT Deny all on WAN_Default (1614537997) 1xx.124.33.4x:23897 xx.157.212.1xx:443
      Like for some reason the traffic that usually goes to the 1_WAN_PUBLIC is trying to go in trough 1_WAN_DEFAULT. After around 45 minutes the problem goes away.
      This only happend to the Inboud traffic (servers not visible to public net), if I use the servers myself from the server itself it can connect to public net and seems to be working just fine.
      What could be causing this?
        joukahainen @joukahainen
        Update 3.3.2021: I noticed that if I will manually do DHCP release and DHCP renew on Pfsense , the traffic will immediately start to work, even though the IP stays the same.
        Running on 2.5 version of Pfsense.
