    Issues connecting with USB-console cable to Cisco switch
    5 Posts 2 Posters 1.5k Views 2 Watching
    • L Offline
      LaUs3r
      Hey guys,
      in addition to my LAN access to my Cisco 3850 I want to have a backup connection via USB-console cable (USB Type A and mini-B).
      I'm desperately trying to connect from my pfSense via the USB-console cable to the switch.
      Here's my status and what I tried. I hope you can help:
      Status:
      • USB-console cable is recognized:
      ugen0.2: <Cisco Cisco USB Console> at usbus0
      umodem0 on uhub0
      umodem0: <Cisco Cisco USB Console, class 2/0, rev 2.00/0.00, addr 10> on usbus0
      umodem0: data interface 1, has no CM over data, has no break
      • it's added as /dev/cuaU0
      • Cisco handbook states the following connection details for the USB-console port:
        9600 baud
        8 data bits
        1 stop bit
        No parity
        None (flow control)
      Problem:
      When I connect with the "cu" command, I get stuck at status "connected" and no input is recognized anymore in the shell. I need to unplug the cable in order to get input back.
      [2.5.0-RELEASE][admin@pfSense]/: cu -l /dev/cuaU0 -s 9600
      Connected
      I tried different speeds and devices like, /dev/ttyU0. Dmesg does not indicate anything once I'm "connected" to the switch.
      When I use Putty from a Windows machine, it just works perfectly.
      Any hints on that?
        That cu command should be all that is required if it's working as expected. I use that all the time to connect to other devices from pfSense. Usually other pfSense devices.
        You could try using tip or screen there instead:
        https://docs.netgate.com/pfsense/en/latest/hardware/connect-to-console.html#id4
        • L Offline
          LaUs3r @stephenw10
          @stephenw10 thx for the hint. I tried tip and screen instead and got the same result. It says "connected", but instead of providing me the username prompt, it's just stuck and no keyboard input is recognized anymore.
          Strangely I can connect from my NAS where I run a virtualized ubuntu using minicom.
          I start to think that this is related to the USB Ports of my pfSense. Maybe I try to put minicom on the pfSense and see if someone in the Cisco forums known that behavior.
          Cheers
            Looks like it could be an issue with that device specifically. A different USB/Serial adapter may well work fine:
            http://freebsd.1045724.x6.nabble.com/umodem0-Cisco-USB-serial-console-and-quirks-td6210309.html
            Not seeing any updates since that suggesting it might now be supported.
            • L Offline
              LaUs3r @stephenw10
              @stephenw10 yeah, it seems really related to the cable. If I use a USB-serial adapter with a serial-console cable it works as expected :-)
