    Problem whit my WAN PPPoE connection
    6 Posts 2 Posters 938 Views 2 Watching
      blue8lucian
      Hello community. This is my first post here. I need some help whit pfSense. A week ago, my WAN connection started to drop from time to time (20 - 30 minutes). I have to reboot the router every time. Can anyone help me? Is the problem from pfSense or the provider box. The provider box is on bridge mode!
      • V Offline
        viragomann @blue8lucian
        @blue8lucian
        Might be the provider, might be the modem, might be pfSense, might be a cable, .... Without more info, nobody can tell you.
        On pfSense you can check the system log for hints.
        B 2 Replies Last reply Reply Quote 0
          blue8lucian @viragomann
          @viragomann Hello. I've replaced the cable....As a pfSense box i'm using an ASrock Intel(R) Pentium(R) Silver J5040 CPU @ 2.00GHz mini itx motherboard .... didn't had any problems whit it.....started to be a problem 10 days ago...From time to time no connection, and the wan it appears disconnected
            @viragomann WAN_PPPOE 10.0.0.1: sendto error: 65
            • V Offline
              @blue8lucian said in Problem whit my WAN PPPoE connection:
              This error tells you that the WAN gateway is not reachable. Nothing more as you're already knowing.
                @viragomann It seems that the problem is only when i download torrents, even if i use a vpn server! need to find a solution
