    Looking for advice on building a low power 1u or 2u pfsense box
    23 Posts 12 Posters 16.8k Views
      dreamslacker
      @Anathematician:
      Someone asked about power consumption. I use the Via Nano which is a bit more power hungry than the Atom. But the Nano has the padlock encryption acceleration engine in hardware.
      But 30 to 40 watts depending on load.
      Via Nano 1.6ghz
      2gb ram
      5400 rpm drive
      intel pci-e dual gigabit card.
      Are you using the VB8001?  I'm considering switching over to the VB8001 and already have the Intel PT Dual-port adapter.
        Anathematician
        Yes, the VB8001.
          dreamslacker
          @Anathematician:
          Yes, the VB8001.
          Ok…  Cool!  Next item on my buy list then.
