    Design help for better control
    24 Posts 3 Posters 2.4k Views 3 Watching
      moosport @johnpoz
      @johnpoz
      No multiple hosts. Just one host.
      No vlan traffic is captured in vswitch. Only default vlan traffic is in the trace.
      johnpozJ 2 Replies Last reply Reply Quote 0
        johnpoz LAYER 8 Global Moderator @moosport
        @moosport well where did you come up with you need vdswitch then?
          @moosport said in Design help for better control:
          That has zero to do with vdswitch..
            moosport @johnpoz
            @johnpoz root cause analysis was suggested in a different forum.
            Wire shark did capture vlan traffic on port going to ESX host. But pktcap-uw did not capture any on vmnic. Promiscuous mode was enabled too.
            Switch configuration is correct.
            Only data point which I still could not figure out is wireshark trace contains icmpv6 but not icmp dhcp discovery.
            Neither ipv6 is enable on pfsense or unifi.
